It's not completely unsuitable, just not optimal. The values are a bit off, and there's a lot of other drivers better suited for subwoofer duty IMO.
In short, I'd use the 15-600LF in some OB or closed box solution without hesitation, not optimal for semi-compact TL/BR.
What other drivers are accessible for you?
Edit, if you're ordering from Thomann the "the box 15LB075-UW4" works just fine in the same box. Cheaper than the Fane 15-600LF.
the box 15LB075-UW4 Speaker 15" – Musikhaus Thomann
Thanks a lot for your answer. Wenn you say "values a bit off" you mean that the t/s parameters in the datasheet are not accurate?
I chose it based on sims for a 210 lit bass reflex box (text book maximally flat allignement).
Yes i' m ordering from Thomann.
Edit: it will be the main bass speaker from 40 (-3db based on sim) to 250 HZ, i don't need a sub.
Thanks again,
Greetings
Konstantinos
