Break in phono with a cd player
Hello !
I have a Diy MM phono preamp that I want to use a cd player to break it in. Hopfully I can put a cd on repeat and let it play for som days, before start to listen to it With my turntable.
I under stand that this is posible with a resistor on the cable, buth dont know the value in ohm. Do anybody have eksperience With this ?
Re capacitors, read these articles for a more nuanced approach to real-world capacitors and their imperfections, including changes with time under bias. Cyril Bateman's Capacitor Sound articles | Linear Audio NL
(and no, they don't need burning in)
My inverse-RIAA circuit I stuck in a little diecast box:
888k = 820k + 68k
3.7nF = 2.2nF || 1.5nF
600 ohm = 1k2 || 1k2
Can't remember the attenuation factor, I forgot to write it on the box! It definitely worked reasonably well with playing music and test tones through my RIAA preamp designs, not that I claim its hugely accurate.
Capacitors are mechanical devices, they break-in.
dave
They were 'semi-mechanical' devices when large sheets of metal were suspended by insulators at a time when Marconi was attempting trans-Atlantic radio transmission. Are they still being used in modern electronics?
I can not fully agree about that, as I have eksperiensed that cd, amplifier, preamplifier and cable have sounded bether after playing som hours.
That is your brain 'breaking in' and has nothing to do with the components.
