Boyuu hifi Equis A10 EL34B+6N2 SE Tube Amplifier with 5Z4P rectifier: review and mod
You bought a Boyuu A10 amplifier, you know that a Chinese man put it in for you.
In the description you read:
Use 0.35, 96-60 large power core manufacturing, design power of 200W to ensure adequate power and low temperature rise.(HIFI EXQUIS) - IT'S A LIE!
You have a transformer 96-50 Take a look, please BouyyA10 — imgbb.com BoyuuA10 — imgbb.com Bouyy-A10 — imgbb.com
sooner or later it will burn you smoking.
Dear Logroad,
do I have to run the cold mode of the all above treats before, to get a conclusion. please help give me a good schematic, that is safe (SOA) running on the power transformer.
Thanks.
Amplifier circuit one you can see,
For the amplifier to work well and in the cold mode, you need a powerful transformer and not the one that the Chinese shoved. Good, I highlighted in red
Hello,
I really liked this thread so far. I have a proposal to cascode the parallel input tube to compensate for the miller capacitances. I propose a simple NPN transistor because of space and power concerns as well as the upper element doesn't add anything to the signal.
Benefits are:
- higher bandwidth
- more linear phase in audio band
- higher slew rate
- lower Rout of first stage (1/3 @same power)
- less distorsion (ok, FFT looks worse)
I simulated it in LTSpice. I add the scematic and some pictures. Green is the cascoded and blue is the original signal. Would this work?
  • A-105V4kt66_cascode.zip
diyHeini,
When you propose a change from one circuit to another, can you please tell us what post # you are changing from... Then please provide us with a schematic of what you are proposing to change to. It is real hard to know what you are proposing from a thread that is 66 posts deep.
Thanks for your remark! I will correct that.
My generall proposal was a input cascode.
I referred to the schematic posted by ygg-it in post #11.
Here is the LTSpice schematic as a picture.
Cascode input:
C16 220nF and R6 10k will be -3 dB at 72 Hz, and -1 dB at 144Hz. R6 will cause the KT66 to draw very high plate current. It is DC coupled from the plates of the input tubes to the control grid.
Are you using R6 for Schade Negative Feedback? That is what R6 effectively is.
R12 75k? Cascode collector is very high impedance, that is in parallel with R12, 75k That has to drive the KT66 miller capacitance (higher C in triode mode than in Pentode mode). It also has to drive the node of R6, C16, and control grid.
What does R2 dummy resistor do? Are you going to use 100 Ohm grid stopper resistors for each 6N2P grid? R17. There are no individual 1680 Ohm self bias resistors for the two input triode cathodes, current may not be balanced. It will need individual bypass caps.
Non Cascode input:
R20 has to drive the miller C of the input tubes. May need a lower value. Instead take out R20. Put a 1k Ohm grid stopper resistor on each input grid (right at the tube socket tab). R3 Dummy, what does it do? R17. There are no individual 1680 Ohm self bias resistors for the two input triode cathodes, current may not be balanced. It will need individual bypass caps.
The triode input stage is a lower impedance drive for the triode wired KT66, Good.
Power supply:
I do not use capacitors across HV diodes. Instead use a higher voltage diode if needed. Once, when I had troubles with 1000V diodes, I just went ahead and used Hexfred 8A 1200V diodes there (expensive, and overkill, but they should not die, and the supply was quiet). I use power strips with transient suppressors.
Put bleeder resistors across one of the B+ caps. Safety first.
DonQ,
You have just a little under 300V B+.
I use 2 each 25k 5W wire-wound resistors in series.
That is 10W total.
300V / 50k = 6mA
6mA x 300V = 1.8W
10W/1.8W = 5.5 x margin.
The resistors will be relatively cool.
You could use 2 each 25k 3 W resistors (6 W total), but the margin would only be 3.33.
The resistors will be a bit on the warm side.
Just wondering if you liked the Triod mod
That is very simple and cheap: you just need one simple changeover switch: A (COM, Common) is connected to B for UL mode or to C for triode mode.
Just cut the A-B wiring, insert the switch with common in A, and wire C to the other terminal of the switch.
Leave the resistor as it is, so you can have a safe screen grid protection in both the ways.
Switch between A-B and A-C only after powered-off and after having waited for twenty seconds.
It took me much more time to drill the hole in the stainless steel chassis!
BachAudioDK,
Max DC current is an unknown spec.
Which factor are you concerned with?
Examples:
1. The DC current that will degrade or destroy the primary wire.
2. The DC current that will cause large distortion at 20Hz (due to saturation).
3. The DC current that will cause large distortion at 80Hz (due to saturation).
3, 2, and 1 are at increasing DC current levels, in that order.
I just bought a used A9
What tubes can I try / without any modes ?
I will be running Klipsch Heresies 1 on the 4 ohm tapas these are really a 6ohm speaker
I will try the 8ohm taps as well
I only want to roll the tubes with out doing any modes as doing the mods is over my hear. Also I’m in the states and will be running at US voltage
