For my daughter's boyfriend's Christmas present I decided to build him a system. I wanted to keep costs down but at the same time come up with a good sounding system. Everything had to be re-purposed since my daughter is, ahem, really into the Green. So I set off to Salvation Army and lo and behold, a pair of Bose 301s in a sorry state. So that became the focal point of a crossoverless system. First get rid of the drivers (BTW, if anyone needs 301 drivers in need of coning, message me). I also picked up an old sony subwoofer with a busted amp.
Photo-2019-12-07-8-53-15-AM — imgbb.com
Next, the crossovers. I only left the tweeter components, which will be used for the super-tweeter. The full range drivers are directly fed.
Photo-2019-12-07-8-53-32-AM — imgbb.com
Photo-2019-12-07-9-24-53-AM — imgbb.com
The drivers selected:
Photo-2019-12-07-9-35-02-AM — imgbb.com
Photo-2019-12-07-9-34-20-AM — imgbb.com
Photo-2019-12-07-9-32-37-AM — imgbb.com
Final result:
In case the image doesn't show up:
Photo-2019-12-14-11-09-52-AM — imgbb.com
It is paired with a class D amp with subwoofer support. You can dial in nicely the highs and the lows. Sounds pretty impressive and looks fantastic in a sixties way..
Hi. Well done! How do the ps180s sound. I selected those for my TL project with inspiration from the Baby Labs models. Still to construct.
3770-D097-E16-D-474-D-9452-63-C147374-A88 — imgbb.com
Corner fortified with L bracket glued and installed.
You’ll be happy with them. The bass is a bit shy without the proper port. I wished the one on the Bose was longer but it does have a weird enough geometry (45 degrees to some mouth) that who knows what it does. The highs are very clear and extended. Nothing wrong with the midrange to high.Hi. Well done! How do the ps180s sound. I selected those for my TL project with inspiration from the Baby Labs models. Still to construct.
- Full Range
- Bose 301 Reimagined
