Bob Cordell's Power amplifier book
That is a beautiful amplifier. 300wpc @ 8 ohms X 8. 128 pounds!! Holy cow!!
It is nicely spec'd. They say explicitly that noise is wrt rated output. They also say 30 uV A weighted at the output, and gain = 28.
<0.05% up to 20kHz is not great, but who knows how much margin they are using.
Bob
Something smells fishy. 300W in 8ohm is 70V peak. The electrolytics in the photo are 63V.
300w could be peak power, that is 150W sine. This, I'm buying, it matches the transformer sizes, the electrolytic voltage and the number of output pairs (two each channel, apparently) and the cooling system physical size (apparently forced air).
Hi Richard,
I'd like to say that you've exposed the secret for extreme insensitivity to external noise with driven guards and another level of shielding. You're talking about normal practice in research and calibration labs. Application in the consumer area might be a tough go for the increased cost. It might actually really help in phono applications, and in the preamp to amp signal run.
-Chris
Yes. It deserves more consideration and coverage complete with T&M data.
A lot more useful perhaps than going over and over the same issues with a microscope.
THx-RNMarsh
Hi Richard,
Well, I think just the fact that this is a standard construction method for high end T&M should carry a little weight. I think a lot of us are familiar with the concepts, and then there are those that should be asking questions. Not about data points. It's the entire concept that bears discussion.
This is a subject that the design by ear crowd just won't get.
-Chris
Hi Richard,
-Chris
Where do we get the cable? This is no ordinary cable.
I hate the way the word "pure" is used in audio discussions. Also, it is a "pure" A-B amplifier I suppose.
Anyway, using terms like pure in describing anything usually is trying to convey some positive attribute before any judgement has been done by the other party. Sometimes the situation is more like "Pure class C", as in RF amplifier use (obviously an exaggeration).
-Chris
Yes. According to the brochure it can also deliver 8 x 450 Wrms/4 Ohm. Quite a beast, fully differential, pure balanced, as they say. 😇
You may be right (I see two output coils on each board) but then 16x150W simultaneously requires 4kW of transformers. Those two transformers in the photo are max. 1kW each. Not to mention that the cooling, even forced air as it appears to be, doesn't cut it for almost 1kW of power dissipation (worst case at 4ohm).
Bob, I just used the bog standard procedure for making open loop Bode plots. I am sure you did exact same thing when you simulated Figure 9.7 (p.181) in the first edition of your book.
  1. Identify the complete loop
  2. Find a convenient place to break the loop
  3. Drive an AC test signal at the "input" of the broken loop
  4. Observe the signal at the "output" of the broken loop
  5. Plot magnitude and phase of V(out)/V(in)
  6. Use LTSPICE ".MEAS" statements to read Phase Margin off the plots
I've attached a representative plot of phase margin versus 2T current source "base stopper" resistance. Not all transistor types (i.e. SPICE models) display this behavior in simulation, but many do. Phase margin gets worse before it gets better. 100 ohms is a particularly disastrous choice.
D. Self mentions 2.7Kohm base stoppers on page 72 of the 1st edition of his Small Signal Audio Design book, excerpt below.
Hi Mark,
Thanks!
Bob
As stated earlier, placing a 100 ohm resistor in the base of the reference transistor should clean all of this up (no capacitor need be added). Putting in such a stopper resistor is no big deal. I would keep using this current source where it seems like a good solution. I will definitely address this stability issue in the second edition.
Bob
Embarrassingly, all three Vbe spreaders for the output stages of the first silicon on the AD524 oscillated at 27MHz. Simply integrating the two diodes in the same tub fixed it. Diode connected transistors that is, the gain was much lower than your arrangement because it was simply a small "cheater" resistor to remove a few tens of mV from the Vbe of one of them.
-Chris
I thought the term was simply Class C.
My mentor in IC design used to say "If it works on first silicon, you weren't aggressive enough." God almighty that was a fun place to work.
But he said that in the days before wafer steppers and $100K mask sets {which now cost north of $5M for nosebleed digital}
Two conventional single-ended amplifiers bridged to make a pair of opposite-polarity outputs to double the power is not a true balanced design. The guts of the amplifiers in such a case are just single-ended.
Bob
Agree about that, since sch is not published we don't know, maybe they connected both amps differential inputs as per second pic in post #7613, where each diff pin is not floating but referenced to gnd via 25 k impedance (SAE specs), which is quite common practice in professional equipment, even if opamps are used as the input stage.
