anatech said:
I really ought to order some bulk to pass down to my children. Maybe some belleville washers while I'm at it.
-Chris
Look up a company called Small Parts Inc. and get on there mailing list. Facinating assortment of hardware, metals, plastics, tools, glues, etc.; including metric, and their stock includes the tiny end of the spectrum as well.
Great for anyone who prototypes mechanical stuff. I order from them regularly and they are and excellent company to deal with. The reason to get the catalog is that there website is a bit of a challenge.
Highly recommended.
Hi Mike,
Thank you, that's very kind. I'll do a search right now.
I just hope across the border shipping isn't silly expensive.
-Chris 😉
Edit: That is one cool site!!!
-Chris 😉
anatech said:Hi Bob,
Convert it to a jpg or something (the box has a list of file types). Either that or host the file on a server and link to it. This might be better.
You could also "zip it" and attach the file.
-Chris
Hi Chris,
Thanks. I know I'm a dufus when it comes to computers. I made it into a JPEG and tried to post it, and it still seems not to have worked, as it did not show up when I previewed the post. I must be missing something obvious here. After I put in the text, I go to the box below for attaching a file, just browse to the file and then double click on it. The file path shows in the adjacent window. But when I then preview the post, there is nothing there but the text. This is just what happened when I tried to post the png version. I must be missing a step.
Thanks,
Bob
My feelings exactly, although I am a bit of a nerd.
Once again Small Parts Inc.
Mike.
Hi Bob,
I'll bet the file is too large. There is a size limit of 100 KB I think. Try right clicking it and choose "resize pictures", if you are not running XP, I don't know. If the original file size is less than 100 KB, then just change the suffix and tell us when you post it.
-Chris
Don't worry, this caused me some trouble early on as well.I must be missing a step.
-Chris
Hi Mike,
They have some really neat stuff. Offbeat for sure.
Catalog ought to be on it's way soon.
-Chris
-Chris
Hmmm.........have a look at the 10V-Vce fT vs IC for these devices............
http://www.onsemi.com/pub/Collateral/MJE15028-D.PDF
I will redesign my low-V rail tracking 16A-Iq class-A core with 25 parallel pairs of these instead. 16A Iq/25 = 0.64A. That will put my average class A operating right near the fT peak – 85MHz for the PNP devices and about 70MHz for the NPN’s!
And the low-Ic fT droop is heaps less severe too!
These “driver” transistors are rather cheap and would be great for a conventional low power (<100W) design. They have low Cob and Cib, so you can parallel heaps of devices for SOA headroom without disadvantage.
Glen
Glen
Mr. Pass, you play with bipolars now? 😀Yeah, I hate that. I just had to drill out a batch of Fairchilds, and dulled out 4 drill bits, just like that.
G.Kleinschmidt said:Hmmm.........have a look at the 10V-Vce fT vs IC for these devices............
Better:
http://www.onsemi.com/pub/Collateral/MJE15034-D.PDF
MJL21193 said:
Not really. They only have a max Ic of 4A as opposed to 8A and the fT above 1A Ic is waaayyyy worse. look at the two graphs at the bottom of page 4 (as opposed to the graph on the top right hand corner of page 4 of the MJE15028/MJE15029 datasheet).
Glen
G.Kleinschmidt said:These “driver” transistors are rather cheap and would be great for a conventional low power (<100W) design.
My thoughts exactly for the 250V MJE15032/33 devices when the hurd was still getting them en masse as 25-rail samples from On.(Ft data is not on the sheet, but can be found on diyA with a search)
Example from overhere, with 64 SMT 120MHz ringemitter devices per channel, 32/ch. for the stereo model.
www.arrayaudio.nl/abssnd.html
(trust me, i nagged the head of the vdh coilwinder too)
Hi Bob,
when you preview your posting the Forum software automatically removes the attachment from the dialogue box.
You have to re-insert after each preview.
If it's the wrong type or too big or more than 1000pixels (even way under 100k limit) the reply tells you.
AndrewT said:Hi Bob,
Hi Andrew,
Thanks. Does this mean that I will never see the attachment when I preview the post? Or does it mean that I should see it in the preview, but that I have to just re-attach it before I submit?
I have never seen evidence of the attachment in the preview, even when I tried last night to just attach a zip file.
Thanks,
Bob
I don't recall seeing the attachment when previewing.
That would be a nice change for the Forum's software guys.
anatech said:Hi Pooge,
The power is in your hands to make this idea come to life. Simply wish it and follow the steps to start a new thread.
I think there is value in your idea. Please, cast the first stone!
-Chris 😉
I have started a new thread about biasing/temperature compensation of Thermal Traks here:
Moderator, please move Bob's related posts to the new thread.
Now I wish somebody would come out with some ThermalTrak MOSFETs 🙂
Bob
(Just because we play doesn't mean we're going over to the Dark Side).
Bob
Hi Bob (and Nelson I suppose),
-Chris
That is a slippery slope!(Just because we play doesn't mean we're going over to the Dark Side).
-Chris
- Bob Cordell Interview: BJT vs. MOSFET
