estuart said:
....BTW, are you buzzy with real common source O/P stages? As a matter of fact I do, but these sky rocketing Cgd's at full output swing are a nightmare.
As a matter of fact I prefer CFP output stages for the voltage gain they can provide (2x - 3x is enough), in turn allowing driver to work at a lower voltage than power rails. This makes possible use of high performance wideband drivers (usually modern audio OpAmps) making for relatively simple and compact designs.
For all this to make sense, and being serious loop gain and feedback in the output stage, wideband power devices are a must in my view, which in turn tips the scales toward power MOSFETS, though of course this may be arguable.
Rodolfo
About Q8 in the circuit from my 1996 article:
One of the outputs of the amplifying current mirror was made with two PNP transistors rather than one, because otherwise the power dissipation would become a bit high for a single BC556 or BC560 or whatever. That the only reason why I put Q8 in the circuit. I'm sure it has its own emitter resistor, not just an RC series branch.
Best regards,
Marcel van de Gevel
Best regards,
Marcel van de Gevel
ingrast said:As a matter of fact I prefer CFP output stages for the voltage gain they can provide (2x - 3x is enough), in turn allowing driver to work at a lower voltage than power rails. This makes possible use of high performance wideband drivers (usually modern audio OpAmps) making for relatively simple and compact designs.
Rodolfo
Hi Rodolfo,
Probably, we are on the same track. To confirm this, shall we exchange our schematics? Preferably by e-mail, as mine isn't bullet proof yet.
MarcelvdG said:.............
Best regards,
Marcel van de Gevel
Hi Marcel,
Thanks for explanation.
Regards, Edmond.
estuart said:
Hi Rodolfo,
The output stage I am using is the one posted in the earlier link and has baged probably over 600 trouble free listening hours spread among several amplifiers, though I do not claim it to be bullet proof to be sure. The remainder I cannot publish for the time being, hope to be able soon. My mailing address is ingrast@adinet.com.uy.
Rodolfo
ingrast said:The output stage I am using is the one posted in the earlier link.......
Rodolfo
Please, where?
estuart said:
Please, where?
Here
This link goes directly to the image:
And this to a module's photograph:
Rodolfo
By the way, about the compensation capacitors in my circuit: its a long time ago, but I think I got a bit of overshoot on the non-linear common-mode loop square wave response and it looked cleaner with the capacitors.
I agree that the non-linear common-mode loop has to be fast compared to the differential loop. That is why I used as simple a loop amplifier as practicable and only a very subtle frequency compensation. Two of the capacitors only decouple diode-connected transistors that are supposed to have constant base-emitter voltages anyway. The other two provide a small zero by reducing the local feedback in the amplifying current mirror. They aren't made higher than necessary to get rid of the overshoot.
Best regards,
Marcel
Best regards,
Marcel
MarcelvdG said:..... Two of the capacitors only decouple diode-connected transistors that are supposed to have constant base-emitter voltages anyway. ....
Hi Marcel,
I beg to slightly disagree on this point. Admittedly I have not pursued further with analysis and/or simulations with this circuit, but I guess C39/C40 cannot be considered merely bypass capacitors. That in fact should be negating the active feedback at high frequencies required to prevent full cutoff during the reverse cycle.
Again, I have no time to analyze this in depth so I may be wrong, may be someone lurking here 😉 whose nickname starts with A and ends with _c may ..aheem.. rise to the challenge?
Rodolfo
Upon a second look, it seems the intention with Q2/Q4 was to provide a constant voltage reference, being the signal chain Q1-Q5-Q6 / Q3-Q5-Q7 for each polarity.
Rodolfo
Rodolfo
ingrast said:
Thanks Rodolfo.
And here is my basic O/P stage. Notice the common mode control loop (Q13...Q21), holding Ig at 125mA. As one can see, this loop is based on the design by Marcel van de Gevel.
Also notice that this schematic is FAR from complete. No I/P stage, no compensation, no clamps no protection etc.
Bob Cordell said:Notice that the input capacitance for the ZTX device with 5V on the drain rises sharply at a Vgs of about 2.1 to 2.2 V. Now look at the curve of Id vs Vgs. It is clear that the device has gone above threshold and turned on and entered the linear region long before the gate voltage at which the input capacitance increased sharply. Indeed, threshold is on the order of only about 1.1V.
More significantly, the device is actually entering a highly non-linear regime in the vicinity of Vgs = 2.1V, where the device is actually running out of gas. Look at the Id vs vgs curve.
Hi Bob,
just to illustrate that your assumpton was incorrect, I attach here another graph made from the same data, but showing how the input capacitance corresponds to the drain current for a constant 5V drain voltage. As you may see now clearly the "jump" occurs between 1 and 30 mA and that is most certainly is the beginning of the operation above the threshold.
Cheers
Alex
estuart said:
....And here is my basic O/P stage. Notice the common mode control loop (Q13...Q21), holding Ig at 125mA. As one can see, this loop is based on the design by Marcel van de Gevel...,
Edmond,
Upon a cursory examination, it is not clear to me how current is controled during the opposite cycle for this arrangement.
I guess from the schematic appearance your are using Microcap, it should be interesting to plot device current at various frequencies.
Rodolfo
estuart said:Hi Glen,
In stead of TMC, you might consider NDFL, but, combined with a complementary VAS, it's probably difficult to implement.
estuart said:
Hi Glen,
I've figured out to do this and I've broken the 1ppm barrier.
Some results:
Vo = 19.5Vpp into 4 Ohm -> THD20 = 3ppm W/O TMC
THD20 = 0.8 ppm with TMC.
Also,I solved the problem of the "fighting VAS's", as described by Bob Cordell, see:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=94676&perpage=10&pagenumber=15 post #145
Cheers, Edmond.
Hi Glen,
I've 'slightly' modified your design: cascade transistors removed and used for other tasks:
1. Nested differential feedback (Q19/20)
2. Common mode control loop VAS ((20/21 and Q27/28)
3. VAS over current protection (Q23/24)
Other modifications:
4. Transitional Miller compensation (C19, R47)
5. Input clamp (D1/2)
6 Temperature compensation ((D5...D7)
Simulated specs are not as good as a Halcro, but probably you can't hear a THD20 of 0.8ppm.
Look below for the circuit diagram:
ingrast said:
Edmond,
Rodolfo
Hi Rodolfo,
I'm not sure what you mean by "opposite cycle" , but I assume discharging of one of the gates. As for the "top half", current mirror Q9/Q10 can sink and source quite a hefty amount of current.
Alas, the common control loop can't supply that much, as the current mirror is only biased with 2*5 = 10mA.
I hope I've answered your question, else please specify which device currents you like to see.
PS: I'll be back within 2 hours.
estuart said:
.I'm not sure what you mean by "opposite cycle" , ......., else please specify which device currents you like to see.
Drain current in this case for each output device during the inactive half period. It is supposed to never drop to 0.
Rodolfo
Rodolfo
Hi Rodolfo,
The first graph shows the transient response at 10kHz and C42=c42=0. As you can see, during "turn off", Id never drops below about 40mA. In the next post C42=42=3n3, so the idle current behaves a little bit different.
ingrast said:Drain current in this case for each output device during the inactive half period. It is supposed to never drop to 0.
Rodolfo
And here is the 2nd graph. C42/C43 has been made 3n3 to improve the step response.
x-pro said:
Hi Bob,
Cheers
Alex
Hi Alex,
I don't think I made any wrong assumptions, but things are a matter of degree. The spec sheet I have for this device shows very little, but it does specify a threshold around 1 V, so I was correct in stating that the jump occurs well above threshold.
One has to recognize that this is a device with a rated Rds on of 50 ohms. I believe that if you re-run your test at a Vds of 10V, you will see the knee of the capacitance curve vs current move out accordingly.
The effect you are talking about is real (input capacitance increasing as the device approaches the triode region), but it needs to be put into context and perspective. Get yourself an IRFP240 and do the test, and you will see that the IRFP240 reaches well into the ampere region by the time its input capacitance has doubled if you put, say 10V across it. Well-designed amplifiers obviously have to cope with device capacitances that may double over their various different operating points, but this is not the serious problem you make it out to be (except for designers who don't know what they are doing).
Bob
Fine, this is how my output stage works also, only there are no compensation capacitors.
Your challenge now is to add overload protection and perhaps look for ways of making the whole job simpler cutting on component count if possible.
Rodolfo
- Bob Cordell Interview: BJT vs. MOSFET
