Blown Sundown Salt 8 Amplifier
1. No voltage on speaker terminals
2. no voltage with a static 4 ohm load connected
3. the negative battery terminal (9v battery ) to primary GND is 0 ohms
I've never seen one of these ICs that was in UVLO at 9.3v but let's eliminate the possibility. Disconnect the battery and connect the VB terminal to the 12v B+ through a low-value resistor (1.5 ohms if that's what you have).
Confirm that you have 12v across the VS and VB (black meter probe on VS). If you have 12v, check for high-side drive.
When you install the FETs, make sure that you have none of the various supplies connected to the amp and you made any jumpers or other mods for testing, remove those.
Initial tests on an amp like this is generally best done on low-voltage (on secondary) or limited current for the secondary voltage. Do you have what would be needed for that?
Wil do I'll go back through and make sure everything is reverted to stock configuration. Sadly I do not ! I was trying to get a hold of a cheap amp I could use the voltage rails from. I am going to current limit what I can with the bench top power supply .
You can use the high-voltage FETs. When you have the PS FETs, they are more robust and less likely to fail if there is a problem (unlikely if you confirm that all drive signals are good before installing the FETs).
Do you have any small capacitors of approximately 0.01uf?
Do you have a signal generator that can produce a 100kHz signal?
