Blind Listening Tests & Amplifiers
Re: Re: volts, amps, what does it really matter?
Peter Daniel said:
While you are listening to full-range music, have your assistant slide his fingers away from the amp (down the cord) while maintaining pressure on the cord. As the person’s fingers slide down the cord, you will hear the sound change; it usually is not subtle either. What you will hear is less emphasis on the midrange and a sliding emphasis going deeper and deeper into the bass region as the squeezing fingers get farther and farther away from the amp.
I was under the impression that they were talking about the outside resonances influencing the cord😉
Jorge, you are again too fast drawing conclusions.
Re: Re: Re: volts, amps, what does it really matter?
What outside resonances? The resonances being referred to are the mechanical resonances of the cable itself, owing to the signals flowing through it. Though acoustical energy from the speakers would also be impinging on it to some degree.
But ultimately, as far as I can see the only "effect" would be microscopic movement of the cable, which might result in equally microscopic relative movement between conductors which would result in microscopically small changes in the cable's inductance and capacitance.
but if you want to try something else, try connecting a power cord or interconnect or speaker cable up to a 'scope and then hang it in front of a loudspeaker with some music turned up as loud as possible and see how well the cable functions as a microphone.
se
Re: Speedy Gonzalez...
Tube_Dude said:
Obviously if the variation of current don't produce any vibration...any vibration can't produce any variation of current...
Well techincally, if there is any relative movement between the two conductors, the result will be a change in the cable's inductance and capacitance which would modulate whatever signal's passing through the cable.
But the magnitude of this would be dependent on how much relative movement there is. And unless you've just got some rather thin foils flapping in the breeze, I don't see that you'll get any relative movement to speak of.
se
Re: Re: Re: Re: volts, amps, what does it really matter?
I think we should be talking here only about resonances caused by acoustical energy, since as you eperimented already, the signal flowing through the cable, doesn't produce any detectable resonances, unless you might try using better instruments to detect it😉 But even if they exist, they are negligable comparing to mechanical resonances caused by sound pressure. You can feel those resonances quite easily, by just putting your hand on a top cover of any stereo unit you might be using. As an interesting note, I'm using a pneumatic platform under my CD player and by placing my hand on it I don't feel any resonances of the unit. That might be a reason some people use some sort of wooden blocks and frames under their cables to either reduce resonances or change them for a better sonic effect.
Re: Re: Re: Re: Re: volts, amps, what does it really matter?
Here's one example of a devoted audiophile trying to improve his Home Theatre setup😉
Peter Daniel said:
I think we should be talking here only about resonances caused by acoustical energy, since as you eperimented already, the signal flowing through the cable, doesn't produce any detectable resonances...
Fine with me.
...unless you might try using better instruments to detect it😉
Um... unfortunately my nanometer resolution laser interferometer's at the cleaners. 🙂
Perhaps. I'm not so sure though. I mean, you've got both electric and magnetic fields creating forces between the conductors and any current flowing through the conductors' resistance will produce thermal expansion and contraction, etc.
So I'm not so sure those forces are necessarily negligible compared to sound pressure.
And how easily can you feel them on say a power cord?
A top cover's hardly a fair comparison. A big flat metal diaphragm with with a low resonant frequency hardly compares to some wires wrapped in plastic.
But again, as I said, see how well a cable works as a microphone.
Take one of those 12 volt SLAs you've got and connect it via a 100 ohm series resistor to one end of a simple twisted pair of say 24 gauge hookup wire or similar. A meter or so in length would be fine. Tie a 10k resistor across the other end of the twisted pair. Dangle it in front of a loudspeaker, or better still lay it on top of the loudspeaker so it gets some mechanical coupling with the loudspeaker as well.
Connect your 'scope across the 10k resistor, crank up the speakers as loud as you can, and see what you pick up.
Well such a platform can help with mechanical coupling of vibration. But no matter what I've put equipment on over the years, any large panels on the equipment have still picked up considerable amounts of acoustic vibration.
se
Peter Daniel said:
See the cables and some wooden frames keeping them in the air, off the floor? That the scan I made from Sound and Vision magazine, sorry for bad copy.
Mmmm. Not really. 'Bout the closest thing I see to anything like that is that sort of light bluish arch looking thing down and to the right of the center channel speaker.
I saw one that's absolutely hilarious. I'll see if I can locate it.
se
Everything Matters...
Christopher said:
No Eric, I have not heard your interconnects. But let's assume that there is a real and audible difference with your interconnects. If there is, and you cannot find an appreciable difference in either L,R,or C between yours and the others, then congratulations! You have just made a fundamental discovery in physics! As boring as that may sound, it's a fact. You seem to forget that your speakers only respond to voltage and current. And if you can't modify those paramaters on a magnitude large enough to move a driver, you cannot change the sound. Or in the case of interconnects, on a magnitude large enough to cause a voltage swing in the first amplifier stage it sees. It all comes down to attenuation, if the cable is flat to oh, lets say 100khz, you're done. It doesn't get any more complicated than that.
And Carlos, I hate to say it, but you missed the point again. I'm not saying I'm buying the manufacturer's claims, I'm saying that they don't make any. They carefully word their ads so it looks like their product makes a huge difference to the sound. But they never actually say it. They can't because they know they couldn't support such a claim. Hell, the Cardas ad just shows pictures. They're not taking any chances at all.
You know I shouldn't give these guys any ideas, but, the next thing they'll be doing is seeding all the nervous audiophiles with the idea that cables degrade over time, and no matter how good they were when you bought them, if they've been used alot, at high volumes, they probably should be replaced. "just take a new pair home and compare them to your old ones, you'll be amazed"
Hey Jorge, maybe you could explain how we could do null tests for cables at home?
Chris
Hi Christopher, these interconnects DO make a substantial difference to the sound, and strongly enough to be noted by those who have no knowlege of the usage of these interconnects and power cables.
Those who do know about them do not want to go back to 'normal' cables.
The only useable test gear I have at present is 44k/16 bit sound card, and this is not good enough to show up transfer function changes - I am hunting access to an AP test-set so that I can do so.
The change is not FR per se, more so changing harmonics relationships, maybe phase relationships, and certainly the nature of noise and distortions.
The sonic effect is to make systems and muso instruments sounds cleaner, clearer, and rather more pleasing.
Also, systems are able to go MUCH louder and then without causing aural irritation.
I do not have full measurements or full explanations yet, but I can assure that the effect is entirely real.
This may be an interesting discovery regarding audio recording and reproduction, and as far as I know, it is entirely unique.
Much of the differences between cables is caused by dielectric materials, and these impart characteristic sonic signatures.
It seems that you are a relative newbie to the audio world.
Eric.
