Bliesma M74B three inch dome driver
Hi Jean , I am newbie in this forum and thinking of building a similar 3-way as yours with almost same drivers like Bliesma T34b (with WG) , M74B & Purifi 8'' . So need assistance on the x-over based on your progress . Can you please PM . Thanks
Per PM request, Here are the values for the M74Be twin notch filters posted here earlier in this thread :
26µH // 4.7µF and 26µH // 3.3µF.
Please note that these values will have to be slightly adjusted according to real impedance data of each driver for the max performance.
In general, measure real value of each capacitor, introduce it in VituixCAD, optimize the value of inductor accordingly, wind the coil and adjust the value with a LCR bridge
Reactions: IamJF
May I ask you why you wrote this (no pun intended at all) Any personal experience to share ?
OK, the two serial notch filters are in series with the driver but effect should be largely out of the band pass, don't you think so ?
On many occasions, I added complexity (e.g. notch filter) to my design which sometimes, after blind testing, was found to be beneficial, neutral or detrimental.
The audibility of a resonance, and distortion rise caused by it, is dependent on many factors. Many AES papers document this in great detail.
It would be interesting to know if one can hear the M74B peak in a system when listening to music (not test tones).
If you do find it to be audible, try a passive elliptical LP filter realized by adding a capacitor+resistor across the series inductor of the LP crossover.
Why do you think an elliptical filter would make a difference?
I'm still waiting for the B version ... I have S and A here and already did a listening comparison (wrote a bit in the M74 thread).
THANKS for the link to the Purify paper - finally a good roundup about this effect!
