I use Vishay 2.2uf Caps. They are very good for the moneyOh, sorry my English. I meant suggestion.
Thanks! You are the man!
Enjoyed listening to my records yesterday with this phonostage. I have only MM cartridges, but planning to get MC one also.
When turning off the phonostage I get a big thump from the speakers, even if my preamp/receiver is not turned on the input. I measured the output voltage of left and right channels with multimeter. When turning off the unit, there is a spike between 0 to -5V. Is this normal behavior or I should be worried?
That will be normal behaviour as the internal supply collapses.
You shouldn't get a noise if the input is deselected.
Unfortunately when it's turned on the input, it's even worse. The receiver shuts down and goes into diagnose mode when turned on afterwards. That's what got me scared in the first place and I started to investigate how it works when selecting other input and measuring the voltages.That will be normal behaviour as the internal supply collapses.
Anything I could do about it?
I have never had an issue like that.Unfortunately when it's turned on the input, it's even worse. The receiver shuts down and goes into diagnose mode when turned on afterwards. That's what got me scared in the first place and I started to investigate how it works when selecting other input and measuring the voltages.
Just leave it on lol
Seriously, I know they do soft starts, what about soft stops?
Voltage is not good: if the problem only exists when turning on/off :
startup: riaa first then amp
shutdown: amp first riaa last
I've had that problem long time ago when I built NOS DAC with tube output , you need simple muting circuit like that small board with transformer on the top of the photo:
it requires small transformer , relay few caps , diodes and resistors . Relay is NC and when turned on outputs stays shorted to ground for a time set by capacitors time constant, it also allows time for filaments to warm up before you get output active - once capacitor charges it opens the relay.
There are many variations of these circuit , search for preamp muting on this forum or you can buy muting PCB from Pete Millet but it's completely different/better animal to what I've done :
Muring Relay PCB
+1Voltage is not good: if the problem only exists when turning on/off :
Would a suitable capacitor on the mains switch kill the thump, similar to what I have on my Lenco?
LikelyWould a suitable capacitor on the mains switch kill the thump, similar to what I have on my Lenco?
Thump is a result of capacitors on transformers secondary charging through the lowest impedance path , capacitor on mains won't do anything .
Switching in sequence is fine if one remembers about , muting circuit would be my option as it prevents fairly high voltage appearing on output
To be fair it won't hurt fitting suppression capacitor on the mains switchWould a suitable capacitor on the mains switch kill the thump, similar to what I have on my Lenco?
Muting circuit seems like an interesting project. Not a fan of adding another power supply, but as I understand, it's possible to power it from the preamp also(Preamp Muting Circuit | audioXpress).
Measured the voltages with tubes fitted and V2 & V3 are quite off. Should I investigate more?
I'm using MM mode, tubes are NOS TESLA PCC88 7DJ8 and 6N2P-EW NOS.
V1 1&6 81 83
V1 3&8 2 2
V2 1&6 113 110
V2 3&8 0,82 0,85
V3 1&6 204 205
V3 3&8 116 113
V1 1&6 81 83
V1 3&8 2 2
V2 1&6 113 110
V2 3&8 0,82 0,85
V3 1&6 204 205
V3 3&8 116 113
The voltages are not outside expectation given that your main HT seems low.
V3 1&6 at 205V. Usual HT 230-240V.
What transformer are you using? What is the AC reading on the 165V winding?
The preamp muting circuit on audioXpress has a far too short muting period of 1.5 seconds. The Bigbottle needs around 1 minute as the HT has a soft start characteristic.
You need to change time constant/value of the capacitor to increase the time output is off
Last time I checked it's bit more, 175V. Will recheck tonight. I oredered it from toroidy.pl.What transformer are you using? What is the AC reading on the 165V winding?
- Analogue Source
- Bigbottle Phonostage Builders thread
