Best speaker kit for smallish living room? (13x9x8)
I think with that kind of music you will need a waw, most of those music has a strong bass that most fullrange not can do. I don't know WAW kits that are sold yet as this is not so much build.
But on the other hand, my own design Mark Audio CHN110 MLTL does play dub (even more demanding for bass) rather well on low and medium volume, in that sense that i don't feel the need to switch to my waw for those. It's only on very loud session that the waw setup is needed. I used a Mark Audio Alpair 10.3/Scanspeak 26W8534G00 in sealed boxes as waw. But i don't have plans yet (i suck at cad drawing), and certainly no flatpacks. I thought Dave (Planet10) got plans of his above that you can ask. There is also an interesting design by XRK971 that is very documented (but again no flatpack or kit): 10F/8424 & RS225-8 FAST / WAW Ref Monitor
I thought Scott got a very similar MLTL as mine design for that CHN110 driver i mentioned and for many others that also give good bass on low power (ask him). If you can find a carpenter to build the cabinet for you, you can still do it. Your budget could allow to pay for that as Mark Audio drivers are not that expensive, and you don't need a crossover or a second or third driver for this.
With this you may have to get a lower power amp to be comfortable (on the volume knop). My 32w tube amp is already way to powerfull for this MLTL in a 5x3.5x2.5m (yes i live in the metric world) room. That should be something like double the size of yours.
If you want a bookshelf, you will loose some bass, but there are designs that still give a lot. My design used in my homeoffice goes to F3 of 45Hz clean with a Mark Audio Alpair 10.3M driver, and that is lower than many multiway bookshelfs. Dave and Scott can you also give other plans (but no kits i thought). Off this bookshelf a friend made a cad drawing so that i can give you. But this was made to let the wood be cut with a CNC, and i guess you (or your carpenter) will also need a CNC machine to cut those... But to get an id you can still look at it. And it's free to use.
  • Mark-Audio-Alpair-10M-Slot-Ported-Official-CAD-drawings.pdf
The mark audio drivers in the mar-ken trap boxes are great sounding speakers bass down to 40 -3db clean to 45 on stands. Play pretty loud but at max (ear hurt level ) volume will bottom out. That may be my fault I may not have enough clearance behind the driver. I do not know if with electronic music will have the bass slam you are looking for. That being said the imaging sound stage are very good.the sound is very clean and the fr is quite good. The ones I build are Mar-Ken10.3T stand mounted speaker.
I am not meaning to steal the thread and would like ask Dave a question. and dont want to start a new thread
Dave I have a quick question I followed your link to scottmooses thread and saw a stand mount speaker with two drivers. Can I add a second driver to the marken 10,3T the reason is when I built them I glued the baffle upside down on one of the speakers. the sound is the same but I would like them to match. adding a couple of drivers would be easier than building a new box. I am using the metal drivers. Or would it affect the sound. thank you
They are all good. In something like the FHXL the cabinet dominates and bass extends to something like 35 Hz.
The A11ms with its monoSuspension will be the most finessed midTop, but may hav eissue at higher volumes in the LF. The A10.3 is a well tested and well liked driver (teh A11ms is new, the A10.3 the old), with 2 suspensions perhaps a bit more control at lower frequencies, but with a deficit up higher.
The Fostex with its larger cone has the potential to move more air and have more satisfactory bass levels.
I am currently listening to a box with the big brother to the 3” nandappe mentions with 2xPeerless 830870 in an ML-TL acting as bass helpers. They are every good. I have quite. af ew other very good speakers. It is easy to end up with way to many.
The point is that there are many choices, i pointed out some i thot might be most appropriate given the limited info provided and my experience — likely way more than most, but still only a fraction of what is out there. I have learned to be very careful when talking about drivers i have not played with.
Look around. explore, cruise Scott’s thread and pick out some boxes and or drivers that look interesting and we can explore options further.
I am sure others will chime in with their experiences.
Let me quickly mention 2 other drivers i have heard that might suit — Mark Audio CHN-110 and the SEAS FA22 (a simple sealed box, so fairly straightforward — if Bob is doing a flat-pak for you that is likely not an issue).
Each offers a different perspective on the music, with different strengths and weaknesses (keep in mind that a loudspeaker has more weaknesses than strengths, ie different compromises).
dave
There are so many options out there, it's pretty overwhelming sometimes! You mention limited info provided on my part-- is there anything I can add that would help narrow the choices further? If it helps, I'd prefer to not reinvent the wheel-- if there is a tried and true design (like the Pensils you've mentioned) then I'm happy to stick with something like those 🙂
My projector screen brackets are adjustable, with a maximum of approximately 22.5" of screen clearance from the wall. From where I sit, a perfect speaker toe-in, aimed behind my head, is 20 degrees. A 16.5"x12" length speaker cabinet (Pensil 12 for this example) at 20 degrees is about 20" from the wall on the longest side, which gives ~2.5 inches of movement from the wall, so I think 16.5" is the maximum allowance for a cabinet depth (assuming a 12" width). I'm not sure what these measurements do for clarifying how large of a speaker design I can accomodate in my living room, but I figure it would help a bit 🙂
Thank you Dave these are the Mar-Ken10.3T stand mounted speaker.trapezoid on the planset it is page 66 should I follow the filter options for two drivers in the planset? thank you again. I have been doing more critical listening and they really are quite remarkable.
Thank you Dave lets hold up on that. I wanted to know if it could be done I am debating a new cabinet vs buying two more drivers. Is there any other benefit like less excursion? I wont be able to do any woodworking for several weeks. (broken ankle) thank you for responding now that I know it is possible I have more options. thanks again
Do not forget that the enclosure plays a large role.
And it terms of moving air you have to look at the swept volume, not the cone area.
Something like the FHXL has LF gain so the driver does not have to work as hard at LF.
dave
I can second that, some box designs emphase the bass so that even a small driver (on low volume) can give a lot. Especially horn and TL type of speakers are good at that. Combine that with a driver that has some bass from itself (low enough FS) and enough xmax and you will be surprised (i was) how much bass you can get out of a 5 or 6" driver in the right cabinet.
Ah, that makes total sense with regard to bass presence by cabinet design. Appreciate all the information-- y'all are selling me on these Mark Audio drivers for sure 🙂
The MAOP series looks pretty cool and that video you posted of the Vok song with the MAOP 10 packs a serious punch. Markaudio MAOP 11 Full Range Speaker Driver | KJF Audio it says here that the MAOP 11 is a direct drop-in replacement/upgrade to the Alpair 11ms, the bigger brother to the 10. Cost aside, and probably not answerable given how many drivers are out there, but how would the MAOP 11 compare to the Alpair 11ms? Because even if they sound similarly, at very least they're really really pretty 😱
The Pensil design with the MAOP 11 drivers seems like it's calling me haha
Dear Xovaan,
MAOP11 and Alpair11MS are in the same direction in terms of sound quality.
I think your choice will change depending on whether you focus on quality or cost.
Sound Quarity
MAOP10 > MAOP11 > Alpair11MS > Alpair10.3 > CHR-90
(The sound quality is not different as the price difference)
Cost Paformance
Alpair10.3 > CHR-90 > Alpair11MS > MAOP10 > MAOP11
(The cone area is different, but the amount of bass is about the same )
I think Pensil10 and Pensil11 are good choices.
