best Place for Star Ground?
The Grounding Issue
I've mixed up some of my schematics. . .
My DC power supply for testing has everything tied to earth ground.
Most of my audio equipment is using a floating ground.
Some of the Rane equipment has a ground lift switch to allow
signal ground to reach earth ground through a passive network
or not connect to the earth ground. But the chassis is always
connected to earth ground in a three prong situation. The
signal ground is it's own star or bus.
Example of direct connection of Ground
Here is seen the signal ground and chassis ground connected,
but the power supply for this circuit is a floating ground. . .so
no direct connection. . .
Grounding Diagram
I guess we can talk about the same thing if we look at the same
diagram. . .uploaded is a diagram of a power supply with some
numbered switches. . .
Potential unsafe mains schematic removed.
Switch Locations 2
Switch four and five closed would have the earth ground equal
to the chassis ground. . .the transformer electrostatic shield/case
would also be tied to earth ground. . .the signal ground would
remain floating.
Switch Locations 5
If all switches are shut. . . nothing bad will happen.
Some equipment does operate in such a fashion. I admit that it
would be a specially designed circuit. . . the engineer would
have to know what they are doing. . .but this diagram is to be
used to discuss the some likely grounding schemes.
Supporting Evidence
http://www.equitech.com/support/wiring.html
"When chassis and audio grounds are connected to the center tap of a balanced AC isolation transformer, they are referenced to the mean AC voltage differential which is equivalent to the zero crossing point of the AC sine wave. There is no current or voltage on the center tap -- here is a clean single-point ground reference for audio. Virtually all chassis, audio grounds and shields can be referenced back to this single point. The center tap of the transformer is then grounded to earth for safety and to shunt any electromagnetic and radio frequency interference away from shields and chassis."
AndrewT said:
the diagrams in post 36 and post 37 are absolute balderdash.
I agree that as drawn there are issues with the schemes presented. The picture translates to using the chassis as a plane type ground for all supply-input-output-safety grounds. the results of this would be a problem to stabilize and the resultant sound would be two-D and congested. There is no way to eliminate interference between the various functional blocks.
I wonder, having attempted to present such diagrams in the past, what the true intent was. I am also curious to examine the correct approach to component grounding.
Andrew, can you post a link to the descriptions you mentioned as being a guide for your efforts? I've been to the Self site but other than references to grounding and cabling diagrams I do not find the overall approach that you mention. I've built a couple of chip amps to experiment with and this input would broaden my experiments.
Regards, Mike.
