Passive crossovers allow a speaker system to FUNCTION, but not very well compared to an active system (which blows passive systems away!). Period, end of story.
nice but your opinion only
No, I'm afraid this is fact shared by several trained pros in this industry. You're welcome to hold onto that idea though.
A passive crossover is a cost consideration that allows the product to work at minimal cost. I'm sorry, but facts are facts.
When a speaker is driven directly, resonances are damped out, output is controlled in the crossover region and rolloffs actually occur following the shape and order of the crossover. It is much more dynamic and transparent. A cheap electronic system will kill a more expensive passive system for sound quality. I remember being blown away by a cheap system compared to a passive one that cost more than 2x more.
Weird phenomenon indeed, enough old non polar crossover caps found in well used speakers measure low but some measure way too high.Hi Salas, I have never measured a capacitor that has increased in value greatly in a crossover over time - ever. So what you are seeing is new to me, and I can't think of any wear mechanism that would cause this. I would suspect they were mislabelled and were maybe even higher when installed. Not unless you are measuring in-circuit where you may have some capacitance effectively in parallel. Depending on test frequency, you may have a resistor or inductor that allows another capacitor to be in circuit unexpectedly.
That is why I tried to also find third party evidence so I stumbled on those two crossover recap videos. They clearly measured the caps with one leg lifted in both videos.
Yes, what originally happened in design and assembly like mislabeled parts or different test frequency spec shall remain a mystery. Same about revisions and surviving official service guides with schematics. 1kHz was shown used in the second video which is very logical for the application. Smack center in the audio spectrum octave wise.
Hi Salas,
Yes, I always measured capacitors in their designed operating range for frequency. There isn't a lot of point in measuring a woofer zobel or crossover cap at 1 KHz unless that is on the slope down.
I'd say what you ran into is extremely weird, never heard of this until you brought it up. Nor have I ever measured a cap higher than it's marked value out of circuit in an old crossover. Of course I do ignore capacitance values if the D/A is bad. I wouldn't know if the instrument was unhappy, or the cap is defective. The latter wouldn't matter since I already know it is toast.
I wonder if there is one actual brand involved here (you can buy capacitors from a factory and have your name put on it). This is a head scratcher for sure!
In first video the supposed 5.6uF but 84.56uF reading cap is in the tweeter circuit. In the second video the supposed 6uF but 17uF reading cap is in the midrange driver circuit.
I noticed. Did the tweeter survive? lol!
Honestly, I believe what you have posted, but this isn't anywhere near normal. Without being able to measure the parts myself I can't say anything - including how his instrument reacts to various defects.
Yes it survived! Due to its very high ESR defect also, that cap worked primarily as a series resistor. Thus a high ratio L-Pad formed between the "cap" and the tweeter. So this HF driver received very little power, it practically went mute until that cap was replaced.
this PDF I have found by accident - go to PDF in post #125 under
https://www.diyaudio.com/community/threads/best-capacitors-for-power-supplies-update.299666/page-7
Interesting document , but who buy capacitors in what they call the "open" market 🤔
capacitors have to be bought at official suppliers ONLY , isn't it 😉
I'm in need of a few cathode bypass capacitors, voltages from 25V to 100V. In terms of value, 100uF would probably be OK. I'm also in the UK so would buy here unless some unusual offer presented itself. To explore the options I just bought quads of these from Hi-Fi Collective:
Elna Silmic II - 100uF, 25V
Nichicon Muse KZ - 100uF, 100V
Nichicon GoldTune KG - 4,700uF, 35V
Any comments on the above?
What else should I try that's as good or better?
kemet dc-link ,bipolar green nichiconhat else should I try that's as good or better?
I have some Kemet DC Link for my own use but I need to build a couple of amps for friends.
I haven't heard a recommendation of the Nichicon ES bipolars - can you guys tell me more, and what it compares with?
The (now labeled) Nichicon UES series capacitors are excellent and inexpensive. Just try them.
https://www.diyaudio.com/community/...lar-caps-measured-120db-thd-140db-imd.270676/
In a previous post I read that solid polymer caps are good for cathode bypass. Farnell UK have these, what do you think?
https://uk.farnell.com/nichicon/rns1e101mdn1ph/cap-100-f-25v/dp/2841885 RNS1E101MDN1PH 100uF, 25V 10x12.5 radial £1.70
https://uk.farnell.com/nichicon/plf1c471mdo1/cap-470-f-16v-20-can/dp/1580591 PLF1C471MDO1 470uF, 16V 60p
> dc link polyprop caps are good?...
Yes, very good. I have several Kemet C4AQ. They're more expensive and virtually unobtainable in the UK right now - long lead times.
Vishay and Epcos are more expensive again.
- Design & Build
- Parts
- Best electrolytic capacitors
