Best 18" pro woofer for econowave w/SEOS-18
The only 1" CD I can think of that can officially do this is the BMS 4550
18Sound HD1050 blue vs 4550 16 Ohm red, Sica 10" WG, @1m, same voltage:
the best pro 18" for what you are trying to achieve is Faital Pro 18FH500 and 18FH510...
the reason is the low mms...
MM
-T-
MM
with 4x 8" can give a better midrange IMO (since you will have subs <100hz)
would look really cool too....
eminence alpha 8a.... cheap and cheerful!
