Bargain woofer, midbass, cone mid thread
old site-
MFK Projects- MCM Drivers- high qts-open baffle
http://www.mfk-projects.com/my_projects/Projects 2015/MCM woofers.html
10" MCM 55-2972 $11.38 usd
from MFK ,"Distortion data for a 1 watt and 5 watt inputs... (1 watt from 10 Hz to 3 KHz and 5 watts from 20 Hz to 1 KHz) Also, impedance and frequency response. Frequency response was measured with the drivers in open air, no baffle."
https://www.newark.com/mcm-audio-select/55-2972/10-woofer-with-poly-conerubber/dp/80R7011?st=10
MFK graph, QTS 1.62, Vas ?
MCM manufacturer graph
QTS .4516, Vas 82.27 litres
MCM 55-2972 25cm Tieftöner Tiefmitteltöner Bass Woofer Lautsprecher 10 ...
The specs are different MFK vs MCM manufacturer.
from PartsExpress
SEAS A26 Tweeter substitution and Revised Crossover
https://techtalk.parts-express.com/...26-tweeter-substitution-and-revised-crossover
Seas A26RE4 (H1411)​
https://hificompass.com/en/speakers/measurements/seas/seas-a26re4-h1411
 a26re4_315mm_2v83_0grad
I've been looking at 10" woofers for a Devore Orangutan, Seas A26 alternative.
Could the 55-2972 be used? With a high qts (MFK measured @ 3.5 times(!!!) the published spec). Any suggestions for a box?
Open baffle or open back box only possibilities?
Anyone use the 55-2972 woofers?
https://eminence.com/pages/support__understanding-loudspeaker-data
https://vinylsound.ca/products/devore-fidelity-orangutan-o-96-speakers
$21,756.00 CAD (they even include stands, how generous)
Reactions: GM
I just recycled my (DS-215-8) 8" woofer of 15 years !!!
PE still sells it.... and it's still made in Taiwan.
I now know how to properly mate it with a soft dome (learned how to build crossovers- yahhh!!).
This guy , actually has a valid design for it - https://www.mtg-designs.com/diy-speaker-plans
Lots of other PE speaker designs/variants with well thought-out crossovers.
Add a zoble ( 10R + 22uF) and it mates well with any 2-3Khz dome (or horn).
The light paper cone plus the monster motor can do very good mids.
I have abused these drivers with Badger/Wolverine AB amps , never fried them.
AND they sound real good (for cheap).
Actually , I wish I could build a 3-way system with these drivers but have no tools to do so.
But , then I would choose the RS-225-8 .... looks way cool with more Xmax.
OS
  • Thank You
Reactions: GM
8" GRS 8SW-4, 8" Poly Cone Subwoofer- 4 ohm (Graph doesn't look like a subwoofer)
Sale price $13.99 usd Parts Express
08-18-2022, 09:47 AM
DrewsBrews
Attached are in-box measurement of the woofer. One is distortion the other is gated. As I said, I wouldn't be afraid to use it all the way to 1K. It might even do well as an old school 2-way using the top end roll off as the crossover.
Sorry for potato quality pictures but its all I have (I think).
MTG Designs
https://www.mtg-designs.com/diy-speaker-plans/flex-8
https://www.mtg-designs.com/diy-speaker-plans/flex-8/flex-8-grs
"I am glad I tested all the woofers I had as it resulted in one making the cut that I didn't even consider initially, the GRS 8SW-4. The 8SW-4 has smooth frequency response up past 2 kHz which was totally unexpected since it is labeled as a subwoofer. Funny how it's actually better suited for 2-way designs and has a smoother frequency response then any of GRS's other 8" woofers."
GRS 8SW, 8" Subwoofer PE Projects page-
https://projectgallery.parts-express.com/speaker-projects/basic-subwoofer/
I used the GRS 8SW-4 as a bass-mid in a 2 way with excellent results:
Reactions: GM and ChrisABC
https://www.parts-express.com/GRS-8SW-4-8-Poly-Cone-Subwoofer-4-Ohm-292-480?quantity=1
The XSD Speaker | Page 34 | diyAudio
https://techtalk.parts-express.com/forum/tech-talk-forum/1489532-le-petite-sarcophage-r2
from post #10
08-17-2022, 05:45 AM
It's no Revelator, but I wouldn't hesitate to use it to the 1K I used here. Pair it with something like the Beast Mode tweeter in a 6 or 8 inch waveguide and it would make a cool, cheap large 2-way.
from post # 12
DrewsBrews
MTG Designs
1.8 cuft (@51 litres) box 5/8" 26"x16.5x9.5 Sealed
(+ Tweeter + (add for ear height) Stands 9" + 26 (35"x16.5x9.5 sealed)
or build a empty bottom section, like this-
https://www.seas.no/index.php?optio...s-aphel-kit&catid=66:seas-diy-kits&Itemid=345
Mini Devore or bigger O/baby Wide Baffle/ wide body speaker look.
8" MCM 55-2960 $19.33 usd Newark
https://www.newark.com/multicomp-pro/55-2960/woofer-8-die-cast-professional/dp/13T7692
from Mike Chua
https://ampslab-spk.com/2018/04/27/mcm-55-2960/
https://ampslab-spk.com/2018/05/26/mcm-55-2960-fountek-fe85/
https://ampslab-spk.com/2018/05/30/mcm-55-2960-pyle-pds442/
looks like a built in BBC dip
Ported Box = 25 liters. Baffle Width = 13.5″
MCM 55-2960 RAW FREQUENCY RESPONSE
No crossover is used. Audition with woofer in RAW state.
Mid-Bass (80Hz-125Hz) – Dynamic. Detail. Tight. No Bloom.
Low Bass (40Hz) – Audible. No Bloom.
Vocals (125Hz upwards) – Sounds Flat. No audible peaks.
Bass and Vocals Balance – Good. Bass doesn’t over-power voices.
Despite the widely different Thiele & Small Parameters, the MCM 55-2960 sounds perfectly fine.
Suitable for PA and even HiFi. Fantastic value for $15.21.
Updated on Dec 8, 2023"
from Midwest Audio Club - MAC
https://diy.midwestaudio.club/discussion/comment/46720#Comment_46720
hifiside
November 2023
Multicomp 8” 55-2960
It would seem that there are some CHEAP drivers that advertise/claim to be subwoofers when they are not actually so.
My opinion is that the Fs & QTS of this driver means that it is NOT a subwoofer > The price however is SUPER DOOPER LOW !!!
Reactions: ChrisABC
Thank You 🙂 Perry Marshall, for your measurements of the GRS 8SW-4 Subwoofer.
I was stuck looking at the specs where it says,"useable frequency range 40-800 hz" & "Subwoofer"
Perry Marshall, "it also has sufficiently smooth midrange response out to 3.5K, that in a pinch, you could use it with no crossover components at all."
I was wondering what's correct (if anything)? The freq response graph looks correct (Manufacturer, PE Board -Drew & Perry Marshall)
3500 hz crossover possibility small tweeter Dayton ND20FB
http://www.zaphaudio.com/ZDT3.5.html
This is a sealed enclosure, 26″W x 16 1/2″H x 9 1/2″D
The enclosure is made from 5/8″ particle board.
Similar to 2022 price $5,600 usd without stands. $1000 usd stands
Devore O/Baby HWD 35"x 14.75" x 9.75" (including 12" tall $1000 usd wood stands)
https://theaudiobeatnik.com/devore-fidelity-orangutan-o-baby-speakers-review/
A possible O/Baby alternative- not a clone, no Seas woofer, not $6,600 usd.
Cheaper than $1,000 usd Devore stands. Nice plywood baffles.
DeVore Orangutan O/baby | Audio Creativ
Reactions: GM
Do you have any opinion about how the Dayton compares to the Peerless / Tymph that looks very similar? I've got a couple of the Peerless in my it-was-on-sale-so-I-bought-it box but I haven't used them yet.
https://www.parts-express.com/Peerless-BC25SC06-04-1-Textile-Dome-Tweeter-264-1028?quantity=1
Very different, I've used them both. The Peerless / Tymph has a much smaller, more sharply flared waveguide and is omni-directional @ 2K and only directional above 5K. The Dayton has a broader waveguide which begins to become directional above 2K and is pattern is much closer to "constant directivity". I have posted a lot of threads about Constant Directivity dipole designs here. Based on that I prefer the Dayton.
Don't believe the marketing description, believe the measurements.
Yes you can use it as a cheap sub, it has a good Xmax, and I've used it that way before, but it's also a perfectly competent bass mid.
Another GRS "Subwoofer", that doesn't look like a Subwoofer. PE $21 usd
GRS 10SW-4 Subwoofer 34-800 hz
https://www.parts-express.com/GRS-10SW-4-10-Poly-Cone-Subwoofer-4-Ohm-292-482?quantity=1
https://www.parts-express.com/pedocs/specs/GRS Spec Sheets/292-482--grs-10sw-4-spec-sheet.pdf
Would those two peaks @ 1800 to 2500 be objectionable?
Could this work for a minimal, no crossover woofer like Devore / Seas A26?
vs
Seas A26
https://www.madisoundspeakerstore.c...s-prestige-a26re4-h1411-10-paper-cone-woofer/
Madisound $224 usd
Reactions: perrymarshall
Hmm, assuming you want a high XO point and/or low order XO, then 34400/pi/5.1 = ~2147 Hz VC dia., so a $0.98 tweak to cover over the dustcap's glue joint should damp the ~1800 Hz and adding some acoustical damping to the dustcap should quell the ~2500 Hz or personally would just cover the whole area as required or suspend a damping disc in front of the driver.
Would Blu tack work?
iu
(1) Roll out small balls of Blu Tack, flatten apply to cone- bunch of small dots.
(2) Flatten Blu Tack to a thin sheet, apply to the cone-might fall off?
(3) Strips of electrical tape applied to the dustcap.
etc
Or Glue a felt disk on the dustcap @ 4 3/4" per PE Q&A,
Interesting. GRS 10sw-4 $21 usd PE + $_ tweak.
Less than Seas A26re $224
Would it be possible to get (?)_% of the sound for 10% of the price.
Can't recall ever using Blu Tak nor heard of it before joining the long gone Basslist and it's been used a lot tweaking (not so) cheap drivers here on DIYA re damping mechanical vibrations (chassis, motor, horns, XO components, etc.), but don't recall it being used on driver cones.
Yeah, PE's tweak works, though surprised it doesn't cover its glue joint that normally 'highlights' DC breakup modes and FWIW my fave is using a suitably sized star shape sticker.
Can't comment about modern consumer drivers, but me, Dave p10 and numerous others have converted many a 'dirt' cheap driver into true HIFI performers IF (big IF) it has a basically good motor design and used within its design limitations; i.e. 'you can't make a silk purse out of a Sow's ear' such as you can put a Ferrari body on a VW 'Beatle' chassis, but it sure won't perform like one.
While perusing the madisound site I bumped into their Black Friday sale. @perrymarshall had mentioned that the Satori TW29 Beryllium tweeter were outstanding but they are still pretty expensive at the $329 each sale price. So I consoled myself with $35 SB26ADC tweeters instead (which are still a bargain at their regular price). I have a WG to try on them. The Dayton ND25FW tweeters were too cheap to pass up on sale for @ $8.50 each, so I grabbed a couple of those at PE. I expect we won't be seeing these prices come next year with talk of tariffs but fingers crossed. The SB20PFCR30-8 are a great deal too at $35 but not sure about the 5db drop at 900Hz.
Reactions: GM
