Bad alternator whine in rockford rf2002 amp in any system its hooked up in.
Hello, I have a Rockford rf2002 amplifier that has a nasty alternator whine NO MATTER which system it's attached to, and nothing solves it. I unhook it, and the whine goes away. The whine is system wide and goes away when I disconnect the amplifier. What electronic components could be faulty? A schematic would help.
I took a picture of some numbers on the board by the input terminals. Is that the pc#?
That's it. You'll have to get it from Rockford or from someone else here. In the attached diagram, you can see two diodes marked ED, D5 and D6. Do you have anything similar (near the TL494 IC)?
The big diodes on the right and bottom of the picture? I tested those and there's resistance in the kiloohms.
If you don't find anything wrong with the amplifier, and all your cables are properly shielded and making good connections, go with a ground star approach. Run all system grounds to one place. So that implies insulating the chassis of all equipment in the system from the car with the exception of maybe the head unit if the star ground point is located there.
