you Guyz know something I don't know, regarding destiny of Babelfish XA252 ?
try those tricks when Pa post few Snails ...... it's easy to tease Poor ZM, be brave and do the same to Mighty Pa ......
Mister ZM, can I just order the pucks for xa252 at mouser? This way I can release my mouser order for Sissysit MOSFETs from shipping costs😉 so no additional requirements on them, assuming I will build xa252 (so non SIT nor Schade)?
certainly
you know Papa's Doctrine - Snatch them while you can, in highest quantity you can
that's how he's greening even now, when Toshibe JFets from Yore are unobtanium, while he's sittin' on Drekload Quantity
wanna try few more tiny things with present XA252 specimen on my T-Bed, and then I can wrap it up
Though Papa was very clear on THf 51 snatch m while you can, I like to believe (might be fairy tales, even on diyaudio) that if I don't buy them, there is plenty other happy audiophiles enjoying them, and not scalpers (often =<my age). Pa should make it more cryptic as his advice is more solid then most acting in the professional field. I'd say let's keep it best kept secret as this is not about earnings😉
Ps. Let's see how long 2sk60 2sj18's last
For future kit using IXTN40P50P/IXFN140N30P, what are matching requirements if relevant with these devices?
Russellc
Russellc
Hello Robin De Wolf,
the prices for the IXYS-monsterpucks went up...
https://www.conrad.de/de/p/ixys-ixfn140n30p-mosfet-1-n-kanal-700-w-sot-227b-160782.html?refresh=true
https://www.voelkner.de/products/30...Input=ixys ixfn140n30&frm=ffs_ixys ixfn140n30
but available...
Cheers
Dirk 😉
but available...
Cheers
Dirk 😉
and for the p-channel...
https://www.mouser.de/ProductDetail/IXYS/IXTN40P50P?qs=cvHLLyFtoE1kNTQtysDwug==
271 in stock
https://www.digikey.de/de/products/detail/ixys/IXTN40P50P/1995388 4 in stock
Cheers
Dirk
271 in stock
Cheers
Dirk
and for the 9240:
https://octopart.com/search?autosug...0+mosfet&q=irf+9240+mosfet+transistor&specs=1
I hope this helps... 😗
- Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
