Re: 2SJ109
they even not replied to my several mails,from few accounts (to jump through potential spam fillters ) ........
all I can is just to
btw-for my knowledge Borbely always have them
Michael Mik said:Hello Cviller
www.fibra-brandt.com will still have some, in December I payed
EUR 4.57 each..
Good luck
Zen Mod said:blur 5
Hi Choky
Seems to be a "daughter" board, not the main. Please confirm
BTW I know 2sj109bl/v from my Borbely Servo 100 monoblock
is that a match for comon 2sj209?
JC Fardo said:
Hi Choky
regarding "blur 5" that's pic of Oly's little symmetric amp pcb.....not connected to Babelfish in any way,except as sideway project 😉,resulted as (in that moment) for me discovered "NP's way" of driving output mosfets
talking about 2SJ109BL (V) ....complement pair is 2SK389BL (V)
I have made a draft schematic of what might become my fishamp.
I don't know if it will be any good. I haven't calculated the values, but most of it is copied from chokys babbel. I have taken the CCS from aleph 30.
The most different thing about my fish is that it uses separate supplies for input and output. I have some toroids with 10x17V@1.5A and 1x18V@2A, so I figured I could try something like this.
What do you think? Is it just a bad idea?
The motivation is to let the first stage operate on a unstrained supply.
First the amp.
First the amp.
cviller said:I have made a draft schematic of what might become my fishamp.
First the amp.
without looking at anything else.........DANGER!!!!!!!!
did you realize that entire modulation of output stage is from R211,and that resistor is referenced to -Ve,same as Q204 gate is referenced to -Ve,and that mosfet Q204 is biased also according to -Ve..........
if you split -Ve for input and output stage,you make two different references.........without further clarifications (supply modulation,supply ripple,different RC constants in two supplys).....I'll just say..........no-no
just for record............I have same thoughts.........once or twice or trice before........ 😉
cviller said:Now I ditched the dual supply in schematics.
Choky, why is one of the jfet drains connected to r21 on your schem?
Besides a fatal error - is the amp and psu reasonable? Should I add more capacitance to the rails?
gimme psu voltages and type of input jfets
sorta folded cascode
In this thread?? 2sj109 of course! 😉
The 2 toroids are 10 x 17V 1.5A. I've measured them with my meter and they appear to be matched with a difference less than 10mV.
Oh I see. I will have to read up on that to fully understand it.
ok;
check the schmtc...............look at output (tip: where are your paralleled resistors)........
don't hurry and try to understand how each block works ;
in one moment you'll hear "snap" between ears
also- you need even 10 mA through your R211 to open that gate (of Q204)........that's no-no,at least in my books 😉 you'll fry them,sooner or later........or instantly............so-you can't use so low value for R211
Usually the gate stoppers are at 221r. You can just as well use that , since you will need a truckload of 221r's for NP projects anyway😉 (R213, R214, R219 and R220).
Steen🙂
Steen🙂
I meant on poor 2SJ109.....when I mention frying
I know! Those poor exclusive fets...
I just got most of the parts I need. Still waiting for the fets though. And I'm not building anything before I'm sure I'm not just making expensive smoke!
I might just stick to the original babbelfish ccs and only change output devices. I've just read so often that people seems to prefer NP's usual ccs, but there is no point in using it if it delivers too much current.
Are the bc's better than ztx450 or only chosen due to availability? It looks like (http://www.6moons.com/audioreviews/firstwatt3/alephj.html) NP is still using ztx's. And if I'm going to use two pairs of output devices, perhaps I should also duplicate the Q4 circuit (in chokys babbel schem) as he does...
cviller said:
Are the bc's better than ztx450 or only chosen due to availability? .......................
same s**t.
use whatever you have in drawer
If I understand you correct; No.And if I'm going to use two pairs of output devices, perhaps I should also duplicate the Q4 circuit (in chokys babbel schem) as he does...
You dont need two Q4 circuits, even if you use output mosfet's in pairs. Q4 turns on the CCS mosfets, no matter how many there are.
BTW Mr pass stated earlier on, that he likes to get supplies for at least 5 years at the time. Thats why you will see him allways using the same parts for many years. That probably also explanes the Zetex choice🙂 (And IRFP240's for that matter😉 )
Steen🙂
pinkmouse said:
Choky, mind your language.
does it counts if I type it with **?
if thats also forbidden.............I'll obey rules
- Babbelfish J PCBs
