Got my KB1 up and running in a nice case. High pitch ringing is pretty intense. Off to Staples for the 6L6 eraser treatment. When it doesn't ring it sings.
Wayne Colburn designs the Pass Labs preamps. 😀 Has for the last 25yr or so...
The Muses 72320 is used as the volume control in all the current Pass Labs preamps, including the XS.
That’s a good enough endorsement for me to want to try it!!
I am very keen to try the Muses on my Build, I have listened to the Korg B1, with a variety of Volume Controls on board.
From Dual Toco's , a Single Pot, Stepped Att, and a Promethius AVC.
The Muses was to let the other owners of the KB1 have a listen to Muses.
I am even more Keen Now ! after being informed it has a inbuilt balance option.
My Investigations to date have been to produce a Dual Mono Volume Control using the Muses to offer the same experience as my Slagle AVC can offer to control the volume on each channel.
The inbuilt Balance Control should I hope be a decent alternative.
This looks useful:
Audio Boards | academyaudio
Toroidy transformer and Salas BiB Salas SSLV1.3 UltraBiB shunt regulator
Is 25V 50VA (or higher) suitable, to achieve 24V output? The UltraBib thread is pretty big, I haven't worked my way through it, and in the meantime there are some 25V Toroidy audio grade trafos available at a good price.
Put bib on some dissipation metal.
From Ultra-Bib guide:
Transformers
You should choose enough secondary voltage for the rectified DC across C1 (Vin) to reach 5V higher (or more) than your Vout setting. Rectified DC=(VAC*1.414)-1.4V diodes drop. Use 9VAC for 5- 7Vout, 12VAC for 8-10Vout, 15VAC for 11-15Vout, 18VAC for 16-19Vout and so on and so forth up to 33VAC max secondary not to burn a JFET. The reg works even with less than 5V difference because CCmA weakening starts only at Vin-Vout <1.7V for ~200 CCmA settings. At 600mA CC it starts weakening at Vin-Vout <2.5V. But more voltage space allows for mains play and for better M1's parasitic capacitance. For VA choose transformers with three times the power of your CCmA*ACV across all their utilized secondaries. A 50VA toroidal transfo for up to +/- 300mA CC should suffice.
Transformers
Just adhered the 6L6 promoted Prismacolor Magic Rub eraser via double-sided tape onto Korg Nutube. Some magic was acheived, as there was an immediate elimation of microphonic ringing. A $3 pack is $4 at Staples. I could not find any other local store that carried them. I am wondering if making four chassis feet out of the remaining two erasers (cut each in half) would further help. May give it try. Thanks, 6L6!
Even in a sealed chassis, I had to rubber-mount the board and blue-tack a piece of damping material to the tube. Once done, it rings a little when snapping the big source switch on the front panel. Worth the work 🙂
I have yet to mount the board to the chassis. Bought rubber mounts on ebay per recommendation in this forum, but not sure how best to secure them to the chassis (not using kit chassis). I was thinking blue-tack.
Just apply a cover of blue tak ...
at each end of the “tube” -over the “tube” surface and distributed also to the board around-. The ringing my built unit had was solved.
Transformers
Thanks - newb alert so please bear with me if you can.
So, if the transformer secondary VAC is 25V, then rectified DC across C1 = (25*1.414)-1.4 = 33.95V which is greater than 24+5 = 29V so a good choice Voltage-wise.
My understanding is that the B1K circuit draws less than 100mA CC, so a 50VA transformer should be ample.
I used a transformer with 22v secondaries(22.9 in use) and a 3R3 resistor for R1. Very pleased with the sound quality.
Go for it 🙂
😀 Yes B1K is a treasure
My AVC + Elma etc. total cost ~ 500$.
Need jfet buffer as well..
TVC of good quality is hard to make and can be x2~3 times price of
autoformer volume control
Hi Soundhappy
Sorry to link to an old post, but—what AVC is this? Looks very good!
thanks: david
Hi Myleftear
All I know about this AVC : was hand made in Fukuoka Japan , 23 steps.
Non commercial brand and non boutique on line.
Dave Slagle is small scale production as well but with available shop
intact audio
intact audio
MeanWell interference
Hey there, I am having mixed results with the Meanwell PSU, it seems to randomly start oscillating and radiating really nasty RF, which gets picked up by various other components in the chain. I have a krell preamp, which is particularly susceptible. anyone else having problems with those little Meanwell powersupplies?
Maybe there's an idea or two in this design, that you might find useful
https://www.diyaudio.com/forums/ana...-preamps-hpa-korg-nutube-etc.html#post6197841
- B1 with Korg Triode
