Nothing bugs me more than the sound of caps in the signal. Obligatto's dont bother me at all. Cant tell they are there. Using those Premium Obligattos and they are pricey for a cap but not for a boutique cap which they certainly qualify as.
Uriah
Are you using the Gold ,Copper,or film in oil.
10,000uF 50v Nichicon KG caps - bought these from Percy a decade ago, but you can get them from PartsConnexion now too
1uF 200v Vitamin Q - eBay. These are hard to find in lower voltages. They are wonderful sounding but also very toxic. Minimize the handling and don't eat fried chicken or lick your fingers after soldering. (Good advice anyway I suppose!)
Are you serious that Vitamin Q caps are toxic ( at the outside ) or are you joking ?! As I have small stock of Vitamin Q caps left I am curious. I don't like toxic stuff except for tin/lead solder that is...
I am glad I built a DC coupled B1 "Mezmerize". Cheaper and less mental noise which flavor cap to pick etc.
Hi, I could not find any info on what is inside those caps except that they're paper in mineral oil. Please tell me what's in them.
Sometime the "oil" used in very old PIO caps as well as to cool down Xfrmrs was declared as toxic. I don't know if the oil inside the Vit Q is toxic or not, but I know they are sealed.
OK, I know some transformer oils contained toxic dioxines/polychloorbifenyls but I haven't found any reference to the Vitamin Q caps.
I assume this story is not based on facts.
what's in
Paper and foil actually, new production Vit-Q are impregnated paper only.
You get high on PCBs when a Sprague PIO blows, current production is selfcontaining.
OK, we are going OT here but then Vitamin Q are not toxic except of course for the lead containing solder on the lead wire connections.
On the other hand Sprague PIO contains toxic oil. Thank you for the information Jacco. It is already hard to know your components and their specific features thoroughly but these myths and flaky assumptions don't make it any easier.
Manufacturer of current Vit-Q caps : “Œˆê“d‹@Дޮ‰ïŽÐƒz�[ƒ€ƒy�[ƒW
A lot of general knowledge from the paper days got lost after the web-age transition.
I was referring to original Vit Qs from '50-'60 anyway, I was not aware of their "reissue".
New production is 100% safe for sure, old ones.... who knows. But unless they blow, they don't spill oil even after 50 or 60 years.
The mentioned "Premium Obbligatos" are the gold ones.... well, polished brass indeed 😉
Those are the ones. Very nice sound. Or lack of sound.
Pass B1 caps help !!
Do any of you guys have feedback on a great sounding
capacitor combination to use on B1. I am using vishay 1uf
and Axon 10uf like Nelson.It sounds a little closed in to me
I would still like the warmth but have good resolution
and a fat bass.
and a fat bass.
The B1 has an output impedance of just over 1000r
It may be the receiver that is causing your problem rather than the B1.
I am not sure, I have diyparadise Charlize amp class D.
I'm planning on using a diy LDR (lightspeed) volume control with my B1.
I need some help in wiring to a Pass B1 board in place of the stereo pot.
Thanks,
Kffern
Thanks,
Kffern
Doesn't the Charlize come with an input coupling cap already? Maybe it's the effect of the two coupling caps in the line which causes that?
I thought most units have input coupling caps,
I mean even my Cd player has coupling caps.
Scott
Charlize
From DIY Paradise site: Charlize has Input caps, Charlize 2 does not have.
Cheers Ernst
Cheers Ernst
I am thinking of lowering the 1k output resistor to 330r
I figure this may help open it up a bit,any thoughts.
- B1 Buffer Preamp
