B&W CM10s2: how to dismantle the midrange?
I tried sending a message to BC2013, but I am unable to per conversation module.
Hello, I was reading your past thread and I too am having issues removing the midrange speaker. I tried watching the video but it comes up as private. Can you please grant me access? or please explain how to do it. I really do not want to fudge this up.
Thank you
Gentlemen, the issue has been resolved. A bit of courage and armed with the advice from this thread helped out.
Galu, I had no sound coming from my tweeter. I didn't want to just assume it was the tweeter. I was trying to remove the midrange speaker to access the tweeters connections to make sure there was no loose wires/connections or if it wasn't a failed crossover.
I purchased a spare tweeter full housing to have just in case it was the tweeter. Once I gained access to the tweeter wires I tested the resistance using a ohmmeter and got a reading of .8, the new tweeter read 5.8. The old tweeter was bad so just swapped em out and now we are all good.
