• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
AZ OLED setup kits for Soekris dam1021/1121 control
Please check the order like this picture.If the order is normal,please check the firmware and DF of your dam1021.Because AZ has already issued order, and dam1021 has not responded.
Sorry for my English
I do not understand how it works.
I had previously Soekrisa without AZ, I changed the filters in the console (Windows), connector J3. The differences were heard. NOS @oneonclock filters.
Now I can not hear the difference on AZ. There are only changes on the display.
Soft and filters upload without AZ, so I remove the soekrisa from AZ.
Does changing the filter in AZ work the same as under the console in windows?
In the console for windows, the change after re-start of soekrisa is constant.
I can not change the filters under the console in Windows having soekris in AZ (connector J3)
7V AC is only suitable for direct power supply to 1021. 47/33 PSU output is ± 12V, need 10v-12v AC more appropriate.
Our MCU connection dam1021 is J3 instead of J10, so you can still continue to write firmware via J10.
Hallo audiozen
I will use your SK lite with a dam121. So question is how to connect these ;-)
Am I right to use J2 pin "com_rxd" and "com_ txd" with the SK lite?
Are the J2 pins the same to use for FW updating / serial port comminicaton?
Hallo audiozen
I will use your SK lite with a dam1121.With regard to the connections, the dam1021 and dam1121 differ quite clearly. So question is how to connect a dam1121 ;-)
