Ayuda soundstream L1.2100D
Good evening friends, someone of you will have the part number of the u14 and u6 of this amplifier is Soundstream L1.2100d in advance I appreciate your opinions
Thank you Mr. Perry yes i have 3 regulators of 5v and the drivers are mmbt4403 and mmbt4401 for each bank respectively and of these I found damaged one, but do I still have an output voltage of -50v any ideas or should I replace all the irf640n drivers? I don't think 6n137s are the cause of that or yes?
If there are three SMD 5v regulators in that area, they are like 6n137s.
http://www.bcae1.com/temp/SLA1500.pdf
Hi Perry
Since I see only a single regulator would that change the type of opto that is installed?
OP
When the card is out you may see the negative voltage on the isolators and the regulator. I just finished up an audiopipe that has about the same layout and that negative voltage drove me crazy until I replaced the IC's on the drive board and got it reinstalled.
Ok I will try it .... I already corrected the voltage -69v in the speaker connection, now 1 of the 78m05 regulators presents me with those voltages that I show in the photographs and Mr. Twilliar could you help me with the name of the plate's ic just can to see the tl074c
