Various diagrams for this type of amp give a wide range of values. What's it reading?
Bear in mind that MANY shorts in transformers and inductors are intermittent and removing them from the board to check them breaks the short and makes it seem to be OK. It's virtually always better to find the short while it's in the circuit, undisturbed from it's original mounting (solder and fixative).
Hi, I'm back, I hadn't checked it because I have more work, Oky now I have already checked the inductor and it doesn't have any short and the other voltages are fine at the 5 volts irf640n at the source and gate pins but still doing the same It fails when I connect the inductor makes a squeak, is there any other component connected to the output of the inductor that can land or cause a short?
- General Interest
- Car Audio
- Ayuda soundstream L1.2100D
