The DAC sounds good right from the beginning, first hour is always most critical for warming up. It will further improve over the weeks though, keep it on all the time.
The design has been favourably accepted by everybody, here's some comments I received from the most happy customers:
It is the best DAC in my system ever! Beats two Wadia players, an Audio Note Dac Kit 1.1 with all BG and AN copper in oil caps and tantalum resistors, Bel Canto 2.o and Cal Audio Alpha, using the cheapest interconnect ever, between my modded TL-2x and the DAC.
The units are terrific. I've been running them in for only a few hours now. But man I'm blown away already. This is some really high end sounding ****! Excuse the languange.LOL
I'm already having a blast with how well the overtones are of Pianos and every other instrument that comes through. This Dac is excellent. It lets the music just flow. Everythings there..just more vivid than I've heard it. Separation is amazing with the little combo. It's a match made in heaven with my FTA-2000s. Honestly it's the most musical sounding setup I've ever owned. How's that for a first impression! And the damn things aren't broken in yet. Whatever your doing ..keep right on doing it...your definitely on the right track!
A friend of mine, who's very mysterious and don't want to say much, have built your DAC using AN silver caps, some other exotic parts and different PS. In the end he sold his Audio Note M3 DAC, which was upgraded to M5!!! He claims your DAC is better 🙂
I can't guarantee the authenticity of the last quote though😉
Peter...
what about my email telling you that you're selling them to cheap?????
as usual, keep up the good work 🙂
Joined 2002
Joined 2002
Peter Daniel said:I'm close to finilizing an output buffer stage that can be used in a preamp or DAC. Here's the proposed board layout. The board contains one audio channel and a complete PS (except for transformer). The size is about 2 x 4" .
I think Me / Brent would be good person to give you some feed back on this 😀
Here's the schematic. I was working on that design with another forum member, Veteran, and he provided the layout's concept, I made the final trimmings. Schematic is also drawn by him.
I've been using that buffer in my preamp for last two years, and I'm very happy with a performance. Combining that with an input gain stage and volume control circuit, may create quite attractive line stage.
jleaman said:And till this day i still compar my other audio to this nice sounding device 😀
This was one of the early prototypes, made p2p. Apart for two separate transfomers and different caps in initial filtering, there is not much difference with current DAC version. That DAC was still using ceramic triplets, removing them may improve the sound (or maybe not 😉).
Joined 2002
Flip it over....
Jason... Take a close look at the underside of the board to see them. I haven't changed anything on it yet. In the days when I only had one DAC I was afraid I would have none if I messed with it. Next time it finds its way back to my desk I will bring it up to date and also give it a USB front-end 🙂
Joined 2002
Re: Flip it over....
You are not allowed to put a usb front end on it..
brentw said:Jason... Take a close look at the underside of the board to see them. I haven't changed anything on it yet. In the days when I only had one DAC I was afraid I would have none if I messed with it. Next time it finds its way back to my desk I will bring it up to date and also give it a USB front-end 🙂
Peter Daniel said:Here's the schematic. I was working on that design with another forum member, Veteran, and he provided the layout's concept, I made the final trimmings. Schematic is also drawn by him.
Sorry for being a pain in the neck but without an input cap the servo may possibly want to adjust offset voltage from the stage before the preamp/buffer when things are DC coupled. Just a note to those that may want to try this schematic.
That is a good suggestion and care have to be taken that previous stage provides proper offset. As the name implies, this is an output buffer, not a stand alone circuit.
5 Channel
Peter,
I have on order an LM3875 Dual Mono Premium Kit, but it's not hear yet so I haven't been able to look it over and play with it. I'm planning to use it with an M3, your Green Board DAC (also on order), and CD transport to build a little dedicated CD unit suitable for headphones and small speakers.
But I have read several posts dealing with questions of bridging and multi channel applications, and it seems you have given these boards an amazing amount of flexibility. This has given me the idea to possibly build a home theater amp also.
My question is, for a 5 channel application, would the LM3875 or LM4780 be the better choice. What I am considering is a bridged pair for the front 2 channels for higher power (2 boards?), and a board and a half for the center and rear channels......or what the heck, just go for six channels....2 more boards.
Do both kits have this flexibility? Would one work better than the other? You mentioned the LM3875 would probably have slightly better sound quality, and that is important to me.
Thanks,
Robert
Peter,
Thanks,
Robert
Hi Robert,
Your package shipped October 14th, I will forward the tracking info.
I was using for extended time both LM4780 and LM3875 in bridged mode, and it's not easy to choose preferrence here. The smaller chip seems to be more delicate in perfomance and shows more immediacy, maybe a bit more resolution and overall better control of highs and lows, but not by a large margin. The bigger chip, OTOH, has better drive and a bit fuller sound, sounds more like your typical high power amp, not a chip amp. I'd say, if you have efficient speakers, which are easy to drive go with LM3875, probably in a single ended configuration. If more power is required, go for LM4780, it won't disappoint you either.
I'm presently using LM3875 in bridged mode, but I'm still seriously contemplating going back to a single chip, and the decision is not that easy.
For implementation choices on both chips check those links:
http://www.diyaudio.com/forums/showthread.php?postid=636556#post636556
http://www.diyaudio.com/forums/showthread.php?postid=584319#post584319
The LM4780 has more flexibility, as two chips in one package can be implemented at least in 3 different ways.
The bridged application requires that you provide balanced signal to the amp, as the amp does not perform single ended -> balanced conversion. The bridged amp also runs much warmer than a single chip (if pushed, the temperature is closed to what I was getting with Alephs)
4780 configurations and power supply
Okay, I'm still a confused newbie that needs help figuring out the power requirements.
I'm going to build the 4780 Dual Mono kit (I hope you received my order Peter), and I expect to need it to handle a 4-ohm load.
So, how best to configure that? Parallel? How much output would that provide?
And what transformer would that require? I've read the data sheet until my brain starting smoking and it's not sinking in.
Nearest I can figure is a pair of 20-0-20 150VA toroids?
Am I on the right track? Or? 😕
..Todd J.
..Todd J.
Look at the page 13 of datasheet: http://www.national.com/ds/LM/LM4780.pdf
It is recommended to use parallel config into 4 ohms. With supply +/-35V you'll be getting approx 120W.
I would go with transformer having 2 x 22V secondaries and 300VA per channel. Such transformer will produce 32-34V DC and you'll be still around 100W power output into 4 ohms.
I received your order and it will ship this week.
>>Originally posted by Peter Daniel
>>Look at the page 13 of datasheet: >>http://www.national.com/ds/LM/LM4780.pdf
Thanks, that enlighted me a bit.
I'm curious about the calculation. I thought we multiply RMS output by 1.414 then subtract the voltage dropped by the rectifier stuff, which is about 1.4 volts? Wouldn't 2x22 result in 29.7 V. ? 2x24v. would provide 32.5 wouldn't it? Or am I missing something? (Remember, I am a newbie.)
Cool! Thanks.
..Todd
Cool! Thanks.
..Todd
Also... (and please excuse the dumb questions)
300 VA/channel? Wouldn't that allow about 10 amps per channel? Sounds a bit umm... overzealous isn't it? Even a pair of 225VA toroids pushed to full throttle would probably blow a standard 15A breaker.
I'm not sure city council would let me push it that hard.
Am I missing something there too?
..Todd
..Todd
If you want, you can go with 60 VA trafo's, I'm just telling you what sounds best 😉 If 300VA seems too big, 225 might be more appropriate then, if you worry about city council.
Transormers have voltage regulation margin, which allows specified voltage at full current draw. With normal amp use (or bigger than neccessary transformer) it will never happen, that's why higher voltage than you calculate using formulas.
I'm using 300VA Plitrons on regular basis and this is what I measure on the amps.
- More Vendors...
- Audio Sector
- AudioSector-chip amp kits, dacs, chassis
