sheldon
The majority of headphone users have at one time or another, (perhaps quite a few times ?) tripped over their 10 feet long headphone cords and caused some kind of damage to the headphones or the wiring of the jacks and plug. A tip to sleeve, or ring to sleeve short circuit due to such an accident,would most likely be resented by the amplifier. Many headphone users even have special wooden stands etc. to help with the safety of their headphones.
SandyK
SandyK
Meier-Audio's way, good for sure but a simple switch to short the 120r output resistor takes less room.Perhaps a sensible alternative would be to use 2 separate headphone jacks. Assuming the amplifier has a low output impedance, one socket could have , for example, a 10 ohm (or thereabouts) series resistor at the output, which would not only give an added degree of protection to the amplifier, but to both the listener and the headphones. The second jack could meet the requirements of the I.E.C. standard and incorporate a 120 ohms series resistor.
the frequency scale is in kHz.I like this! Paul, thank you, the Panasonic 003A with 5R coil DCR and 300mA max current looks good, and will give huge attenuation at 100Hz/120Hz, purpose designed, too.
attenuation at 100Hz/120Hz is off the plot.
Some amplifiers to be sure. I think this one is pretty safe as is.
Remember it already has 10R emitter resistors, and is cap coupled to the output. If more is needed, the 317 in the supply will shut down before the output devices overheat.
Sheldon
Makes sense. This choke?: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PLK1302-ND
For PT, something like this?: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=TX3-20V-ND
Wall transformer is not a bad idea, but would have to be sourced for each country.
Sheldon
Sheldon,
I'd not realized that JWMiller is offering flatpack transformers. But digikey isn't actually keeping them in stock and it would require a bulk purchase to source them. Digikey does stock Signal Transformer semi-toroidal flatpack transformers, series LP. But if you do use a separate from the actual amplification unit ps, those semi-toroidal transformer's advantage of smaller
EM field is of less importance. Then an often more readily available split bobbin transformer works quite well.
For me, the major advantage of a separate power supply is that I can comply with 'best practices' wrt to safety, and not have to safety ground the conductive chassis of the actual amplifier, if the voltage is under 50vac or dc,. Dunno about you guys, but for me, a safety grounded signal carrying chassis and hum are often close to inseparable.😡
Regarding switching supplies, I've yet to meet audio component using one that hasn't benefited substantially (subjectively) from a reasonable power conditioner feeding it. A combination choke with 2 flanking X2 capacitors seems to make everything "mo' betta". While the lack of 'Y' caps does compromise potential common mode attenuation, keeping noise off the safety ground eliminates other potential problems, leastwise, for me. Indeed, many switching supplies do have similar filters incorporated into their inputs, but they are there for FCC compliance, and aren't particularly effective for audio use. One would think using the combo CMC on the output of an switching supply would handle both mains and switching supply noise [and the higher current draw minimizing potential 'Q' peaking from the filter as well as allowing more optimal filter characteristics], but my preference, subjectively, has been to filter at the input. This also works with switching amplifiers. Believe it or not, such a filter can actually make a NuForce or Spectron amplifier listenable!
FWIW,
Paul
Could we implement some sort of power limiting?
In the case of a shorted output, the 10R resistors would give some protection, but to be completely protected we would have to disconnect the feedback loop and then adjust offset, which is probably not very easy depending on the amount of feedback, and wouldn't be immune to temperature drift.
We could use an opamp-based limiter connected to the input of the OPS, which would go high or low a few volts in the case of overdrive. This is even improved by the 10R resistors.
- keantoken
- keantoken
Andrew,
Quite right, I'd missed that....
KT,
With a 24V rail and half rail biasing, we'd have 12/10 or 1.2A through the upper device max, same through the lower, and this is well within the SOAR rating of the device (100mS, Vce 12V 2A). We don't need to worry about the output devices; they are fine. I'm not sure we would ever need to disconnect the fb loop - heaven forbid!
Hugh
KT,
Hugh
KT,
Besides the 5 ohm limiting resistor in the power line plus 10 ohm emitter resistor and half rail of 12V.
Worst case will occur when the transistor is biased to drop Vce of 6V across it, then the power dissipation would be a maximum at 400 mA dc and dissipation will be 2.4 watt. Besides there is a series cap in the output and this condition will only exist during square wave testing at half power.
This is a 12.5 watt device, it is well within the safe operating area. It would get pretty hot under these conditions if you have no heatsink at all and leave a white smelly mark on your finger.
Nico
Nico
Guys, I am not convinced that these ferrite core CMC transformers will do any good. What Hugh uses in his power amp is an iron core because it need be for low frequency common mode ripple suppression as Andrew noted.
Nico
Nico
Sorry I may not have been clear 100 mA poly fuse in each amp power rail, not in series with the headphones.
I looked at my can's spec. It says:
Max. nominal long-term input power 500 mW in acc. with EN 60-268-7,
The nominal impedance is 300 Ohm, then I would think it safe to use a 50 mA PolyFuse for protecting my ears rather than the headphones.
I have on an occassion used PolyFuses as emitter resistors in an over worked amp for a club rock band and the amp has been going strong for seven years now.
Well, Since no one else thinks it's a problem, that's pretty convincing for me.
I would calculate it nonetheless, but I don't know how when you add the emitter resistors to the equation. Not to mention, headphone power ratings cannot all be the same.
How does using those as emitter resistors affect the sound? Is it worth it from a design and subjective standpoint?
Thanks,
- keantoken
Thanks,
- keantoken
Joined 2009
That's a good question, I'll be interested in seeing answers to that one.
My thought is that because we're in Class A these resistors cause no problems (any resistor adds noise of course). I suspect they improve stability of the amp into different loads. They define to a large extent the output impedance (ignoring for a minute the additional output resistor we plan to add). To be honest, I've never really thought about them and it's a good thing to look at the different elements of the amp and ask 'why'.
- More Vendors...
- AKSA
- Aspen Headphone Amp
