Are there any excellent inexpensive Chinese DACs?
It seems that for so called audiophiles listening is a holistic experience in which they need to use all their senses and brain. Blind testing is crippling as it cuts out one important sense (vision) so vital information about what is being listened to is missing. This and the lack of expectation bias ruins the holistic listening experience. Blind listening test to audiophiles is similar to listening with ear plugs for non-audiophiles.
Blind listening is a snapshot. It is like getting into a Trabant and starting it up. You put it in reverse it goes backwards. Put it in first and it goes forward. Turn the steering to the right it goes to the right and when the steering is turned to the left it goes the left. You then get out and do the same in a Maybach and it behaves in exactly the same way and on that basis you proclaim there is no difference.
Regarding controlled listening tests of dacs, it isn't worth the cost of doing it. Where people are spending money on listening tests is for patented immersive car audio systems. Follow the money.
...and you can bet they are going for the illusion of soundstage, for each individual passenger.
Doesn't have to be a painting. Most digital cameras have never gotten the color of the rug in my house correct. Sometimes they show it as pink, sometimes as green. Also, sunsets from here do not capture low level contrast of the mountain range peaks 100mi away. Its like they don't exist if you believe the camera. This should be news.
Similarly, there is a price to be paid when digitizing phono so it can be run through room correct and speaker crossover DSP. Its a lossy process.
Have to say you are working very hard to miss the point. Not talking about digital cameras either.
Ohhh, a car analogy ;-D
As far as car analogies go that was probably the worst I've ever seen.
Reactions: TNT
Probably not that easy. We need a measurement that can tell if cues correctly indicate a specific well defined position in cue space (including in the presence of complex music or music-like signals). Also we need to be able assess how much cue position is blured or ambiguated by correlated PN and or AN, and or by other factors.
The "cues" you mention is not a signal propert by itself- it's the result of the well know properties of coneying a signal undistorted. It's really that simple - please don't mystify known science. There is no magic and there isn't anything to "measure" wrt to "cues". But I give you that most, if not all, measurements are single channel and there might be something in that - I think my suggestion would prove channel balance which could effect some positioning and distance of portrayed sound sources in the sound stage - as the stereo "system" tries to do the impossible given its architecture...
As opposed to taking them into Laguna Seca and Rodeo Drive.
Agreed!
As car analogies, conditional dac accelerates to 100 per 10 seconds, good measurements. But imagine this feeling and driving experience in cheepest car and let's suppose Audi or BMW or something else. Both are within the norms of good imagine "SINAD" measurements, but what feelings will you have when you drive it in usual life?
