Any interest here for PLLXO ?
Hi ! I've been working successfully on this type of crossover and ask myself if somebody would be interested in using these on a home multiway system ... 🙄 I'd see a "plug and play" black box with a CF tube amplifier inside .
Freqs would be fix ,12dB slope only. :hohoho:
ok , i tried many solutions, and decided to swap OPamps ... but each PLLXO needs an input buffer , so the tube solution seems to be the best . http://http://retro-forum.com/viewtopic.php?f=14&t=15223&p=95390&hilit=PLLXO#p95390
Hi Coresta,
This looks like a very special and rare application. Looks like there are inductors in there as well.
More generally speaking; my experience is that when applying a PLLXO you need a preamp with enough gain and low output impedance because of the insertion loss in the filter.
2. order filters are doable as long as there is gain enough in the amps.
Best
Kris
I am running four way stereo speakers off PLLXOs, a mix of first and second order.
Insertion loss is handled through use of a couple of OEP brand transformers. Transformers work great if the preamp has enough clout. I imagine a passive preamp for example would not work with this solution.
I use an Excel spreadsheet to calculate the values needed and printed a chart for easy reference. I have however heard such a calculation works for one crossover, but that multiway xovers change the math and then it gets really complicated. I think Minidsp would suit my four way open baffles better.
