Any 3-way using Vifa P11MH09 out there?
Parts List
GOWA said:
Dimensions: 17" H x 10" W x 12.5" D.
Piano-quality black lacquer finish
.75 ft³ net internal volume
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=302-730
You might want to consider another woofer, one with a higher Qts. Above .4 for sealed, below.4 for vented. For this size box (20 litres), you'll need to make sure the Vas is fairly small too - say 30-50 litres.
Example: an 8" woofer with a Qts=.35 and Vas=50 litres will give very good results in this size box vented. F3 would be ~25hz.
