And what did we buy today?
It has too much hysteresis, try and see the specifications on arc welding transformers, the open voltage is about 120V, and on load about 85-90V with a standard 10 SWG arc welding rod, IIRC.
Those coils are made with thick wire or at times flat strips, and will not be very good above 1 kHz, I think.
Reactions: NE WAY
I just bought the new 16 core ryzen 5900XT to revamp my Good ole AsRock X370 MB,
It is a newly designed chip just for this purpose, So, We'll see how it goes....................
Been running on a R1800x since the month the whole series Debuted !! 😉
And about 3-4 weeks ago an Octa Core Banana Pi Bpi-F3 RISCV board showed up on my doorstep to play with.................
A very early 4/16 GB version to boot !!!!
Now you can get one with 8GB or 16GB of ram, and are now available since it was released just a few months ago !!! 🙂
:cheers:
jer 🙂
https://www.facebook.com/photo/?fbid=8429484160409743&set=pcb.8429487910409368
https://www.facebook.com/photo?fbid=8429484750409684&set=pcb.8429487910409368
https://www.facebook.com/photo?fbid=8429486307076195&set=pcb.8429487910409368
https://www.facebook.com/photo/?fbid=8429486657076160&set=pcb.8429487910409368
130A and 34V is probably open circuit volts.
Would need many power transistors to get a high output current at that voltage.
And some are designed for a low duty cycle, and continuous high current would cause heating. Also, heavy windings for arc strike load, and a lower load during the actual weld.
I would not load it at beyond 10% continuous, which is a fair load, and it would possibly be bulky for an amp.
Reactions: NE WAY
More Toshiba JFETs, specifically 2SK170BL and 2SJ74BL, could have bought them back in the day, but was into tubes and could not conceive I would ever be interested in designing with them, now I get to pay through the nose (although in truth I am not paying much more for them than for devices from Linear Systems)
If you don't mind the fact that they're SOT23-5 SMD, 2SK2145BL from Mouser is a fraction the price of 2SK170BL. And if you connect the two devices in a 2SK2145BL in parallel, the resulting device has very similar Cdg and DC characteristics to a 2SK170C but is 1.7dB quieter. Adapter PCBs are easily found for SOT23, but check pricing as some vendors are "imaginative" on pricing.
Reactions: kevinkr
Well I actually bought a vintage arc welding machine (and I went out to buy two more because I was so pleased with this one) aaand trying to use it as the transformer for audio amplifier 🤣
It is capable of 130A, and deliver 34Vrms when connected to 1 ohm load.
Is that a military surplus welder? Very nice in any case!
That is a great tip - thank you. 😀 The design in question was a one off for a specific purpose, but provided it performs to expectation (it measures well) I do plan to replace the 2Sk170BL with SMD parts in my next design. I am very comfortable working with SMD components and prefer them in most situations to TH parts.
My last order from Fair Radio - several of each item.
Too bad they are closed up now, in preparation for their in-person and online auction scheduled for August 15th-17th. Just saying, it may be worth a look to builders and experimenters for general parts, one of a kind, and whatnot. I have no doubt the bulk of items are still there because I've seen pictures of recent "tour" of buildings full of non-catalog stuff and it's way more than in the catalog. This isn't an ad, just a tip for a huge pile coming up.
Anyway I mess with carbon microphones and they have 3 different transformers for those.
The ribbon inductors BTW have some white oxidation spots on the aluminum spool, which needs cleaned off without scratching it. I don't know how to do this, but ya just can't get these any more and if you have the 180 series tuners you may need one.
Denon POA-S10. Just the one for subwoofer duty. Hoping it survives shipping as I have no control over packaging and multiple courier hand-offs :-(
Plan is to use the Rod Elliot project-48a controller and feed to the Denon thence to a Monitor Audio Silver 12 which I picked up for a song as the crappy plate amp was dead.
However..the best laid schemes of mice and audiofools Gang aft agley,
Tomorrow will tell if I have a boat anchor or fun.
https://sound-au.com/project48a.htm
https://sound-au.com/project48.htm
https://reverb.com/item/43947392-de...plifiers-extremely-rare-audiophile-grade-amps
https://www.monitoraudio.com/en/product-ranges/silver-series-7g/silver-w-12-6g/
Yes! works wonderfully. Rod Elliot has nailed it with his project48a.
This works very well with the MA-Silver12 and it's dead crappy plate amp removed and driven externally.
I looked to find some amp that was both affordable and would compliment the current main amp.
The Denon POA-S10 fits the bill and has drive to spare too.
Current system = RPi4>MoOde Audio>DIYinHK USB to i2c>AKM 4137>ProtoDAC TDA1387 X8 project>Perreaux Amplifier>pre-out to-Denon-POA>MonitorAudioS10>Silver12 (and mains=Shahinian ARC)
Happy as a Suidae in ordure.
5 1/2 digit DMM. I've always wanted something a bit more accurate than my handhelds. I continue to be surprised by how inexpensive test equip is today relative to my college years. Less for this 5.5 digit (although probably more like a 4.5 digit true accuracy) than the Fluke the lab I worked in college bought which was a 4.5 digit. I think the fluke was over a grand and I picked this up from rigol for less than 400 with free shipping.
Closed yesterday. I have a porch with a view. 1.19 Acres, half wooded, two car garage (read that workshop, I will add a steel car port for the vehicles), 100sq-ft root cellar, and 100 sq-ft canning room. It needs a bunch of work. The only utility is electricity. it has a 350' deep well for water. Water quality report was very good. pH 7.5, 15pts hardness, zero bacteria count.
I am going to be very, very busy for the next 6months to a year.
Lovely view! Congratulations!
Thanks for mentioning that it was designed for low duty cycle. I don’t think that the welding machine would last very long at 130A if operate continuously for hours.
I did not test it for 130A, 130A is closed circuit.
I connected all my 56 100 ohm, 50W resistors in parallel.
The voltage at o/c was 65V, at 1.8 ohm it dropped to 34V.
At least now I know it is good for 600VA😊
