There's plenty of things that work, but are not (or have not) been understandable at the outset. It's pretty understandable that as we build ourselves out and above that dirty 'ol soil, maintain that state 100% of the time, that there just might be an unanticipated consequence. Given that for a million years or so, we as a species had an electrical conductive connection to the earth's surface via our feet - and in the last 100 or so "we know better" with our plastic shoes on plastic flooring and zero attention paid to the matter.I don’t know, I generally don’t put too much stock in claims that make no sense.
Sure we do...
It's trivially easy to try and you did say you'd try anything at this point. You seem like the type that has some spare wire around; it's cement half A to half B easy.
I noticed those pads I was using read in the 100s of k if not meg Ohms from the connection to the surface where it goes against the skin. Found some brassy looking wooly stuff my wife brought home from the lab 10 years ago, I guess they used it to clean soldering iron tips. Found it'd take on a solder connection. Found it's resistance is more like zero. Got a couple wads of the stuff under my toes in a two wool socks - with a wire coming out - connected to - you guessed it - ground. It's not even uncomfortable to wear.
We'll see.
I have stopped using mouser as they no longer ships low volumes of resistors.Man can I ever relate. I look at the endless stream of Mouser orders over a years time, and the shipping would pay the rent. Thing is, the body won't allow what it used to, so it is a sort of therapy for me.
Mouser has a very good BOM-page where my projects was located. But as they no longer are complete i see
no gain in shopping mouser anymore.
Why would one ever buy resistors in onsey twoseys? I need one, I buy a pack. Then design that value into whatever it’s possible to. You end up with one cabinet of 1/4 watt resistors, 20 or 30 values you use over and over. I never think of any one project - I think what I’m going to use over 10, 20 years. At least in terms of the penny ante commodity stuff.
Goes back to my pet peeve from work. At one time they used to have a P-card and a budget for the test lab. Need something from Mouser? Order it. Running low on 4 pin header or .01 uF 0603’s? Put a batch on the next order. Have actual stock in the lab when you NEED it. Everything got done with a minimum of fuss, very little time and money overall. Now? Not a damn thing. Bean counters want to control every piece of inventory, including NON DELIVERABLE items. Requisition every stinking capacitor and screw from corporate. Not in inventory? No stock number? Get it created through Component Engineering - in about 5 days. The pennies they save on inventory are eaten up with paperwork and employee overhead - not to mention taking their time away from stuff that corporate is tracking with their stinking metrics. Nothing beats having the cheap stuff you need day to day IN YOUR HAND.
And NO, last time I checked, non deliverable internal use items did NOT have to have ISO-9000 traceability on them. Just hardware delivered to spec to a customer.
I do order singular items if there is only one in a device. Keeping all items needed in i BOM will make life
easy when i need to refresh stock, if i want 10 units i just order 10 units a a particular BOM and i have
everything i need for building 10 units.
Mouser however removed this possibility so i'm back at collecting everything at various suppliers. Needless to say that i
use local suppliers then.
Mouser, good bye !
Mouser, good bye !
Around here, Mouser is as close as one can get to a local vendor. The last place you could go in the DFW area to just walk in an buy a resistor or cap without paying $1.75 markup for a three cent item closed it’s doors right befire covid (owner retired). Overpriced blister pack NTE resistors and their potentially fake $6.99 transistors, no thank you. I’ll order a whole pack from somewhere online.
If you walk 5 miles from my house, there is nothing more to see. You get what you can in quantities that you don't really need at the time and are glad you did maybe 5 years later. With the RCA jacks for example, I try to make my order of at least 16 at a time. Many of my unit require at least 8 of those at a time, but it gets expensive so that is a consideration. Penny parts however are another story. 50 resistors at a time if the price is right.
It can be ridiculous though. There are many parts sitting unused maybe because I have changed directions for building over the years.
ebay! But you gotta net at least $10 to even bother, right?There are many parts sitting unused
I bought a Cadet "Hot One" 220V space heater for the garage at a yard sale. They put this God-awful plug on it with the opposite blade flipped horizontal from any 20A socket I happen to have. New plug to fit the socket I have, or new socket to fit the plug on it doubles the cost of the whole thing. Such an innocuous little thing too - thought I'd just plug it it - nope. It's 30 deg out there today... Ah, the satisfaction of Snip 'n toss to the garb can!
Well, I cut the plug and wired on a 220 plug with ground pin and both blades horizontal. I now have a running heater...Yeah, cut the ground prong off and stick it in the wrong socket backwards…..
It wasnt that easy. The Hubbel plug had a metal case attached to the strain relief, which made a spring contact to the ground wire. Reluctant to just whimsically grab onto that, I got my DMM and measured from there to the breaker box case. That was fine, but my old jittery fingers somehow poked the needle tip probe (that happened to be on that DMM) past the strain, into the hole, through the jacket of the black wire and of course making simultaneous contact with the metal shell. That blew off the probe tip, welded the rest of it to the shell. No safety glasses nor Hasmat suit like we had to wear at Amzn to touch anything over 48V.
A probability I wouldnt make up if it were fiction. Back apart it all comes, restrip everything - oops - now the strain relief is on the wires, not the jacket.
Back apart for a 3rd try. Make the wires shorter, get white and black in place, but green just wont go in without fray. Solder the wire tip; the screws have these square washers that will only fall away if it's upside down. A little "Moribund the Burgermeister" going on with "Mother! I say you will" cranking that wire around to fit with pliers. Got the 3rd iteration together, measured 0.0 again (I'm flipping the main panel breaker each time I plug in) and this time, I'm confident to just grab that metal shell and unplug it.
Both blades horizontal is 240V/15A. The plug will fit the 240/20A socket (but not the 120/20A). I have the 240/15 on my compressor. The extension cord has the 20A connectors.
Get some thick tweezers and a long thin pliers pair in your next order, they are handy in such situations.
Thanks. I did. Came with no bracketry, so I DIY'd it to the studs with a couple lengths of 4X9 aluminum sheets. More Moribund, as the bracket edge knocked out the spring captive nut as I was hoisting it in place and I lost it. The nut, that is, for a spell ;')Hope you’ve got it working by now, sure isn’t getting any warmer, that’s for sure!
After getting it in place, I noticed the rubber washers that provide friction need to be between the two surfaces and that aint happening with just one free hand. Maybe if I try one side at a time, with it still hanging from the other, to squeak it in between there.
Makes that space more livable in about an hour run time!
Today I received "EMF Protection Pure Copper Fabric-Blocking RFID Radiation Singal Wifi EMI EMP RF" a 117" x 43" sheet for ~$33 shipped from ebay. Split it with my wife to make two ~58" sheets. Was able to solder to it at 215 C. Painted some water based poly about 1/4" around the periphery, to help reduce possible fraying. I'll try it, just under the cotton bottom fitted sheet to start. They're in place and connected to my previously purchased and installed earth ground rod tonight.
Lots of papers on it, such as; https://www.scirp.org/Journal/PaperInformation.aspx?PaperID=58836
You could have used 24 mesh wire screen, in about 0.25 or less wire diameter (about 10 thousandths of an inch).
An insect screen in metal wire will work, it is basically a Faraday cage in function.
Crimp it to a lug, use copper or galvanized wire to conduct energy.
Keep it under the mattress, so it does not flex and fray.
There is something called Mouringa juice, claimed to be a natural pain and inflammation reliever.
Also try turmeric powder in warm milk, with or without sweetening, good for healing.
Thanks Naresh,
This coppery cloth is probably impossible to find locally, as is anything that's not home renovation specific - these days, here in America. Back when I was a kid / in college you could easily go pick up a pack of 5, 10K resistors from Radio Shack, but no more.
And the next town over is cookie-cutter identical, in terms of finding something odd, like a cloth you could sleep on comfortably, that happens to be conductive. Ebay is my only source for such a raw material shipped from another one of the states, then Alibaba to pay less but wait for it longer.
I've already kidded with my wife "You know those 4 post beds? - Maybe I do the 4 sides, top and bottom with this stuff!" Wouldnt hurt, except maybe getting in and out of the thing in the middle of the night ;')it is basically a Faraday cage in function.
Actualy, those 4 post beds were used to support drapes or mosquito nets, which were cotton in the old days, nd that has some properties which are not found in synthetic fabric, like static resistance for example.
The long fiber Pima cotton was so good that my uncle used to get bed spread sets from the USA on his trips there...
A friend of mine makes jumbo bags in plastic, he puts a conductive fibre every twenty or so reels in warp and weft, the fabric becomes anti static...
I wonder if such a material is available for use on a four poster bed, thin wire may be too stiff for daily folding.
This copper stuff, I assume from China, is soft and flexible enough I can sleep on it bare no problem. Using my DMM I get about 2 Ohms from the end of my 6' connecting wire to one corner. It would easily drape as a mosquito net.thin wire may be too stiff for daily folding.
I have a desk lamp on the nightstand with a metal chain switch. I shuddered when I went to shut it off last night - for obvious reasons. Still alive to type this - going to have to do something about it like choose a different lamp - probably a little piece of plastic away from death.
I bought another hunk of the material for ~15, shipped. One of the "grounding" papers says it helps in meditation - that I've been trying on and off over the past 10 years. I'm willing to give it a try. Cover the little carpet I sit on, so my feet are in contact with it; we'll see.
Perhaps is that doesnt work out, I can use it to cover the inserts of my sneakers, connected to a braid that drags on the ground behind the shoe. To ground an insulating shoe, you have to be sure you're not conducting in cold at the same time, as many electrical conductors are also good at thermal.
- Member Areas
- The Lounge
- And what did we buy today?
