And Now For Something REALLY BIG
Consider though, a light cone and a strong magnet
From reading that Adire paper thread I linked to earlier "Transient response is NOT acceleration; rather, it is the rate of change of acceleration (defined at the jerk force, measured in units of Stapps). Acceleration is SPL - the higher your acceleration, the louder you are.................Anyway, in a driver what limits how fast you can change your acceleration (rate of change of acceleration is the jerk force) is the inductance. That's what limits your transient response. Mass really has nothing to do with transient response. Only efficiency...................Efficiency is affected via mass changes, but transient response is not"
More cells = more better, in my book. At least for typical domestic listening.
Given the choice between multi-cell and "One Hole" horns, I've made my choice. 🙂
so 15 would be better than 8?
Pano, please san I ask for your reasoning (in detail if pos.) why you feel/think that way and made that choice. I very much respect your opinion & knowledge
Then you should get the TD15m. It has light cone, high efficiecny, and Le better than any others @.2mH. That is 25% of most others you have looked at or talked about. It also has light cone.
I think more cells = better because that's what I've heard. Not what someone told me, what I've really heard. 😀 I've heard the multis from 2 to 18 cells. More always seemed better to me. Bigger, more open, more real. That said, the 1005 and 1505 may be the practical limits for home use.
Thanks Pano. I've asked the ebay guy about the cell terminations and I'l let you know what he says. Here's a pic the maker sent me of an 18 cell version.
Wow he was quick!!
"Because of the widening of the of the entrance it keeps all the 15 appertures the same area never thought about it before. they could be tapered if you prefer that would give the outside 6 cell slightly more area"
I guess he means widening at the external cells. I think its because his cells start from a flat plane rather than radiating out, as if from a central point.
What thinks you?
Good questions. I certainly don't know. :scratch:
Ok he's come back with a bit more info - "yes the cells are slightly shorter on the outside banks but the throats make up the differance by being longer on the outside edges"
Does anyone out there speak 'multicellular' fluently? Pano, how are the start of the throats arranged in your horns? Cal maybe you can shed some light?
I doesn't seem 'right' to me 😕
