An illustrated guide to building an F5
Capacitor Voltage Rating depends on your Transformer's Secondary Voltage rating!!!
I would appreciate any guidance on this comment from the BOM Capacitor "Voltage Rating depends on your Transformer's Secondary Voltage rating!!!"
I have a Antek AS-4224 400VA transformer. I plan to use it with either 15,000 35V or 22000 35V.
Can I use either? Or point me toward where to research 2nd windings.
You want to ensure that the voltage rating on the caps has a bit of margin. Cap rating is for maximum DC.
In short, if you're using a transformer with 24V secondaries - 24VAC x 1.4 ~ 33.6VDC ... 50V caps have been more widely used.
re: research - the data sheet on the transformer will tell you the secondary voltage.
I haven't been following the thread too closely, but is there a reason you're using 24V secondaries in an F5? I searched for posts by you. 18V is the most common for a standard F5. I've seen 20, and maybe 22 used occasionally, but personally I've never seen 24 except I think on an F5 Turbo. That could be my lack of knowledge and not reading the full thread. Someone else will surely chime in as to whether that transformer is suitable for this build taking into account the JFETs etc. That's out of my realm.
Edited to add... Rayma beat me to it... I had to pause mid post. :rofl:
Looking for this terminal block
I have searched for the white plastic terminal block shown in the assembly guide without any success. I've found one, but it is pretty large. I'd appreciate it anyone can point me in the right direction.
Thanks,
Chip
hopefully the photo will show up
Thanks,
Chip
For future reference, this is a compatible part:
HE1WPR/06 Altech | Mouser
Although, per previous post, there are better options.
I used this terminal barrier:
TB100-04 Bussmann / Eaton | Mouser
I first soldered the NTC lead to a solder tab with internal lock washer, and screwed that to the terminal barrier.
