Ampre Audio 7.5k
It's strange that you get signal all of the way through without high-frequency oscillation. This could be from a few different things. The first I'd check is the feedback capacitor on the TL072 (typically pin 1 to pin 2). Or possibly the TL072. I've heard of TL072s from one batch/manufacturer working, while another would not.
You could also try injecting a high-frequency (80-100kHz) signal into the TL072 to see if that makes it through to the outputs cleanly.
Without the fets in pin 2 is at 4.6v on the working card and 1.6v on the card that stopped functioning.
I'm leary about putting fets in. I did that earlier causing me to only have 1 working card now. It doesn't appear to be the 21844s chips tho.
Is this modulation? Is this normal? I can't remember.
You won't get modulation at the drive frequency with a self-oscillating amp until it's fully functioning.
Modulation a the varying pulse-width. You've seen it with regulated power supplies.
The SD voltage on the 21844s is controlled by only 2 things, as far as I know. The MAX transistors pull it down during muting/protection and when they're defective. If you lift the MAX transistors, you can eliminate them (or the circuit driving them) as part of the problem. They are driven internally by a very low-current CCS to pull them up (when nothing is pulling that pin down). Lift the MAX transistors, one at a time, to see if the voltage on pin 2 of the 21844 goes towards 5v.
Both cards tl072 chips were defective.
Without fets everything looks fine again but now when I put the fets in it attempts to start but there is what appears the be ringing on the high side. The pictures are a progression of the high side wave
Im just glad I'm not blowing chips anymore with the fets in
