• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Amplifier Modules and PCBs For Sale
D
Deleted member 148505
under board pic
D
My hunch is correct that the sound is being limited by the opamp feedback caps. Might be the group delay between the opamps are different.
In slaa788A, they increased it for stability from 22pF to 330pF (corner freq is ~48kHz in PFFB).
I think as long as the module is stable, the value can be decreased. In my module, the whole amp is stable even when the opamp feedback caps were removed (using LME49860).
Further upgrade is matching the resistors of SE to Diff buffer, as well as PFFB resistors. It will lower down the distortion further.
Joined 2019
I agree the sound is a bit more clearer & airy on the upper end after removal of the 4 feedback caps. Just took them off and listening now (PFFB removed). Will play the amp for the day and see what happens. I have WIMA 1uF caps pre-3255 right now but I’ll put back the Silmic IIs later today to hear the difference. I’m also running OPA1656s.
Cheers, Pete
D
Can you enable the PFFB? or you enabled it but still don't like it?
In my test module, the PFFB is enabled.
I'm not sure for the stability if OPA1656 is used. Do you have LME49860?
Lester
Cheers, Pete
Joined 2019
Lester
Lester: I’ve changed so much at this point it would be a lot of work to re-enable PFFB. The LC is 6.8uH+0.68uF, pre-opamp caps are 4.7uF WIMA MKS, pre-3255 are 1uF WIMA MKS, RA&RB 3-6 have been changed to 50K to prevent low frequency cut off due to the 4.7uF WIMAs. I have the following caps by-passing on pins 4-to-8 of the OPA1656s (10uF Silmic II + 10uF X7R Murata’s + 0.1 uF C0Gs) as per ClaudeG’s work on the Aiyima 3251 amp.
I have 49860s to try .
Pete
Joined 2019
I see, PFFB is now better sounding.
You are using 48V right?
I will check what values are needed to enable PFFB with 6.8uH + 0.68uF.
Maybe osc freq single resistor change is needed. Might take a week.
Lester
To re-iterate, PFFB is disabled on my board. Using 3e Audios 48V SMPS. I have no oscilloscope so I’d have to be able to hear any oscillations. My speakers are 8 ohms. Changing back to the original 10uH+1uF LC structure is easy to do (since I didn’t glue down the inductors ;) ).
Pete
Joined 2019
Lester
Lester, 49860 sounds fine...just not as "pretty" as 1656. Sounds seem to be a trifle more compressed into the speakers than 1656 (on my speakers & system). High frequency clarity is there but not emphasized as much as with 1656s. Just my take..
Really a personal choice of what one likes I guess.
Pete
D
I agree, OPA1656 is cleaner and clearer sounding.
Just need to tame it with ELNA Silmic II or other compatible caps, otherwise it will sound sharp.
I ordered small quantity on digikey, it is out of stock on Mouser!
I agree...and the less polar caps the better
Pete
Pete
