D
Deleted member 148505
Ok, misunderstood from me.
Does the C1-C4 caps really useful as we already have the CA1/2/CB1/2 caps before the opamp?
D
Yes those are needed because the virtual ground of analog input_A to D of TPA3255 is at AVDD/2 or 3.5VDC.
Input caps for the buffer opamp are needed because single supply is used so the ground of opamps is VCC/2 or 6VDC.
Thanks for the explanation.
Pity! The less capacity there is in the signal path, the better. 😎
On the LME49860 datasheet, they use a 27pF or most of the time just a resistor.
D
My hunch is correct that the sound is being limited by the opamp feedback caps. Might be the group delay between the opamps are different.
In slaa788A, they increased it for stability from 22pF to 330pF (corner freq is ~48kHz in PFFB).
I think as long as the module is stable, the value can be decreased. In my module, the whole amp is stable even when the opamp feedback caps were removed (using LME49860).
Further upgrade is matching the resistors of SE to Diff buffer, as well as PFFB resistors. It will lower down the distortion further.
I agree the sound is a bit more clearer & airy on the upper end after removal of the 4 feedback caps. Just took them off and listening now (PFFB removed). Will play the amp for the day and see what happens. I have WIMA 1uF caps pre-3255 right now but I’ll put back the Silmic IIs later today to hear the difference. I’m also running OPA1656s.
Cheers, Pete
D
Can you enable the PFFB? or you enabled it but still don't like it?
In my test module, the PFFB is enabled.
I'm not sure for the stability if OPA1656 is used. Do you have LME49860?
Lester
Lester
Cheers, Pete
Lester
Lester: I’ve changed so much at this point it would be a lot of work to re-enable PFFB. The LC is 6.8uH+0.68uF, pre-opamp caps are 4.7uF WIMA MKS, pre-3255 are 1uF WIMA MKS, RA&RB 3-6 have been changed to 50K to prevent low frequency cut off due to the 4.7uF WIMAs. I have the following caps by-passing on pins 4-to-8 of the OPA1656s (10uF Silmic II + 10uF X7R Murata’s + 0.1 uF C0Gs) as per ClaudeG’s work on the Aiyima 3251 amp.
I have 49860s to try .
Pete
D
I see, PFFB is now better sounding.
You are using 48V right?
I will check what values are needed to enable PFFB with 6.8uH + 0.68uF.
Maybe osc freq single resistor change is needed. Might take a week.
Lester
Lester
Lester
To re-iterate, PFFB is disabled on my board. Using 3e Audios 48V SMPS. I have no oscilloscope so I’d have to be able to hear any oscillations. My speakers are 8 ohms. Changing back to the original 10uH+1uF LC structure is easy to do (since I didn’t glue down the inductors 😉 ).
Pete
I agree...and the less polar caps the better
Pete
D
Pete
I plan to have an external split supply for the opamp buffers on version 2, so that frontend caps will be removed.
Then LM317/337 for onboard opamp supply, if the external supply is ultra low noise, then a clean supply will still go to the opamps.
Lester
Lester, 49860 sounds fine...just not as "pretty" as 1656. Sounds seem to be a trifle more compressed into the speakers than 1656 (on my speakers & system). High frequency clarity is there but not emphasized as much as with 1656s. Just my take..
Really a personal choice of what one likes I guess.
Pete
Yup just removed CA3, CA6, CB3, CB6.
Then caps are all Elna silmic II.
The constrained voice sound was removed.
Difference is phenomenal!
Hello
Which diagram are you referring to?
I guess these are C_op from slaa788?
I only have the TI documentation.
Best regards
Roger
Hello!
I confirm better without the feedback caps. How small are these capacitors!! Impossible to use air flow. Too close from the op-amp sockets. 😀
No yet back with PFFB. Ive to change the green 22uF caps for Elna first.
Stéphane
Stéphane
D
I agree, OPA1656 is cleaner and clearer sounding.
Just need to tame it with ELNA Silmic II or other compatible caps, otherwise it will sound sharp.
I ordered small quantity on digikey, it is out of stock on Mouser!
Pete
Pete
Hello
Best regards
Roger
Roger, I can’t remember where I got this but here ya go!
Pete
- Vendor's Bazaar
- Amplifier Modules and PCBs For Sale
