Amp Camp Pre+Headphone Amp - ACP+
Is C109 (or is that R115) and R109 unintentionally solder bridged together?
Component numbering is all over the place
yes - component numbering on the board is not always apparent.
I think you are looking at R115 - R116 ( I had tried not to have them bridge, but they are linked anyway , so probably does not impact the circuit )
I have attached the schematic so that these part numbers make more sense
Resistance across gate and drain is as follows:
upper mosfet - V111 ~ both boards around 4K
lower mosfet - V112 ~ slowly increases ( starting at about 1K5 ) after 3 min 45K
  • ACPP-M2X_SCH_001.pdf
Founder of XSA-Labs
Joined 2012
Hi Dbel84,
Sorry to see you are having trouble with this board. I seem to to recall you said it used to work but the bias current was too high so it was running hot. Then you tried to change the output source resistors (per my recommendation) and that’s when it started smoking. Did it ever work? I can’t make out the colors on R117 but is that 6R8? Also what do you have on R105 it’s unlabeled? It should be 200R.
Make sure R116 is not shorted to the trace beneath the solder mask that travels beneath it. A 0R resistor is insulated across its body, whereas the wire jumper is not.
Here is a photo of my working amp. It seems to compare well with yours except for the two I indicated as not clear. I put your photo side by side to compare.
Here is the schematic for easy reference:
850196d1591382163-acp-preamp-hpa-yarra-preamp-39b72e46-5acd-4973-891f-74e592e7a373-jpeg
Measure resistance aross pin 1 and pin 2 of the opto
113R
XRK971 said:
Hi Dbel84,
I think it had trouble before which is why it was running so hot , it also pulled the voltage down further than I had anticipated which would make sense if it is was draining close to 2 amps.
R105 is indeed 200R, I changed R117 to 10R. I wonder if it is as simple as the wire jumper. The 0R resistors I bought were too long to fit an I could not use them which is why I substituted the wire.
I will correct this as a next try
Thanks ..dB
Pin 2 to 5 on opto is zero (that is the wire bridge), as is drain to 5.
C4 is correctly oriented.
No change in behaviour after ensuring wire bridge does not short and switching R111(on this board) to 1K5
Edit - I lied 4.3V, just a probe connection issue
Ignore below
I tried to check the gate source differential on V112 and I do not see anything before things start cooking. Wondering if the problem is the front end of the circuit
If there is an equivalent "dumb" award to the Darwin series, please nominate me. I very nearly quietly disappeared and hid my shame. I was rifling through my parts bin to replace the mosfets and I kept finding p channel fets of all variations and the possibility of me using p channel fets instead of n channel slowly began gnawing at my conscience.
I don't think I have ever felt so silly, I knew it was going to be a epic fail on my part and now we know what.
With n channel fets in place it fires up as expected, I now have 100 MA of bias and heatsinks are sitting at a healthy 40deg.
Thank you all for offering to help and sacrificing valuable time for my poor eyesight and failure to make absolutely sure I had the correct parts.
Thanks Nelson for keeping me in mischief..dB
