Amp Camp Amp - ACA
Heat sink tap sizes?
I purchased the chassis set from the diyAudio store for the ACA, but it does not come with machine screws to attach the output transistors or the standoffs needed to attach the PCB. I thought they might be 6-32, but that is not correct. Anyone know the correct sizes for those machine screws (thread size and length)?
M3, as are all other diyAudio 'pre drilled' heatsinks.
12.5mm or 10mm length is my guess - use a matchstick as a depth gauge.
Unequal heat production between channels...
Got my ACAs built, thanks to help from several folks. They do sound very nice with a Norh ACA 2B pre-amp (that I got very cheaply and resurrected) and a pair of speakers that I built with Audio Nirvana drivers.
Here is one weird thing I noticed: both amps constructed identically with the same parts and biased the same; however one of the amps runs very cool (just barely warm even after 3 hrs) while the other runs quite warm (probably 15 to 20 degrees warmer than the other -- not measured). I cannot think of any reason for this behavior and wonder if any of you have any suggestions of what might be causing this?
Heat - The most likely scenarios are;
1) The cooler one has a mosfet that is not thermally coupling to the heatsink very well.
2) The cooler one has an incorrect value resistor somewhere making the bias or CCS gain lower, resulting in less heat.
Thanks for the suggestions. Did a little inspection before undertaking any reworking and found one of the dreaded cold solder joints. All fixed and now it is cooking like its twin!
