that's schm from original ACA simulation , it was easiest to draw additional parts in it
8R is load , ignore it
C1 - put whatever you have ;increased in simulation from other reasons , not necessity
Will the power also increase with this mod.?
You will be able to drive a 4 Ohm load to about 10W.
Ok! 🙂
Wath is it original in 4ohm?
Must maybe add extra 15" Alphas in my MJ King OB`s then... 🙂
I'm thinking about buying the boards for this amp but i would like to use a single enclosure for cost reasons. Before I start is there anything I should be aware of first like potential ground problems?
These topics have been discussed in previous posts to this blog, a few pages back.
I'm attempting to build a dual mono ACA (two supplies, one chassis) and will be mounting one ACA PCB to each heatsink of the same chassis.
I was looking closely at the ACA PCB noticed that the layout has plated through hole mounting holes and those are connected with a trace that runs around the board to provide ground to various components. Because the mounting holes are conductive and the ACA kit (presumably) uses metallic standoffs (as will I), they appear to connect what I would normally consider signal ground to chassis ground at the heatsink.
I thought it was generally accepted that signal grounds should normally come back to a star ground (which then connects to the power supply ground) to avoid noise. If that's the case, why are the through holes plated and effectively connected to chassis ground? Is this simply a compromise for simplicity of installation for the intended audience?
This was my concern too, I assume that since nobody answered this post it's not an issue, thanks for your help.
It`s not an issue on my ACA, davym 🙂 My RCA connectors are isolated, but both pcbs are grounded through standoffs.
How is Amp Camp compared with First Watt F3 / F4 as a dedicated amp for a 1" compression driver* from 3000 Hz?
* Radian 475PB-Be in a Tractrix 1000 horn
Don't know yet. I will build a F-5 first and then maybe a F-4 together with a 2A3 amp. I thibk the camp amp's sound would improve with a better PSU.
same sort of fun factor
Seen lots of talk about the PSU but never anything conclusive? all i can say is Mr pass seems to think its fine and money on upgraded power supply is in the realm of diminishing returns, better to put the money into a better pass amp. Anyhow they are playing now ( The most important part) with the laptop power supplies with a dcb1 and im very happy thanks papa gota go i love this next bit xx
I
Pass DIY Addict
Joined 2000
Hi guys,
I'm building an ACA for use in my office and am planning to put a stepped attenuator in the chassis ahead of the signal input on the board. What is the best value to use in this spot: 25k, 50k, or 100k? When I add this attenuator, should I remove the 10k input resistor?
Thanks,
Eric
Thanks,
Eric
25K , if you're having usual sort of sources
leave 10K resistor in place , it's part of circuit which you don't understand
part of feedback net , defining gain of amp
Pass DIY Addict
Joined 2000
Thanks, Zen! If only I had time in life to understand everything I did 😉
in fact , same NFB arrangement as in your X amps
Pass DIY Addict
Joined 2000
Hmmm... I seem be able to find lots of 50k stepped pots and almost no 25k pots. What are the tradeoffs with using 50k instead of 25k?
Little by little and with the help of others, I'll learn what I need to know... Thanks for the input!
- Amp Camp Amp - ACA
