@JeffYoung
You probably have an ltspice model. I have a request to You. Could you check what the 100hz ripple will be in this configuration: 33000uF capacitors and 0.47R resistors? Now the ripple is 170mVpp. Rail voltages under load +/- 21.7VDC from 18VAC on secondaries. Maybe it will be better?
Thank you Jeff 🙂
Do I correctly suspect there will be a bigger voltage drop?
Regards and Happy New Year
Yes, but not material (~0.05V).
If you're willing to lose some voltage, 1 ohm resistors will nearly halve the ripple again at the loss of about 0.25V.
I have one more board so I can make a better version without desoldering. I wonder whether to install 4pcs 33000uF capacitors before the resistors and 47000uF on each rail after them . Will it be quieter than all 33mF versions?
More resistance leads to lower-voltage rails and more heat in the resistors.
More capacitance before the resistors puts more of a tax on the transformer (and fuses if you don't have a thermistor or other form of soft-start).
More capacitance after the resistors does too, but to a lesser effect.
Thank you Jeff.
I was thinking about a slb power supply but the costs will be much higher with a new transformer so I will work on your project 🙂
Rectifier boards are still on their way, but got 5pcs of these today. Thanks Jeff!
Any gerbers for the rectifier boards? Thanks
If you mean the "Double Bridge" board, they're here:
https://www.diyaudio.com/forums/pass-labs/137145-f3-builders-thread-65.html#post5647859
- Alternate First Watt Power Supply Schematic
