AliExpress DIY AUDIO NOTE MEI SHU <= Is it worth?
@tomchr which schematic would you suggest for a good 300B SET?
If you don't mind a little sand in your glass then this one: https://neurochrome.com/pages/dg300b
An alternative could be the Tubelab SE or SSE. Get the boards while you can: https://www.diyaudio.com/community/...sing-operations-as-of-the-end-of-2023.400691/
The OPT makes a big difference. I've tried Edcor CXSE and Electra-Print with good results. I would trust Monolith too. I hear Toroidy in Poland delivers good toroidal OPTs too.
Tom
Reactions: marcomariutto
I still don't understand the use of sand with tubes in the active parts of circuit.
It is my limit but when it is involved the 300B a simply but efficent driver makes a great help.
And the dg300B is one of the worst I even seen until today.
4,4 mA for the 6N6 for driver stage!! I have some doubt with the right bias point
Walter
