What Is An Aleph Jzm?
The Nelson Pass designed First Watt Aleph J is a classic. @Zen Mod created this version of the Aleph J to make the project more approachable to newer builders while maintaining the characteristics of the original. For more advanced DIYers and those that like to experiment, there are options to use a variety of JFETs and customize the circuit to suit personal tastes. For those that don't know Zen Mod, he was gracious enough to post a video to introduce himself and share a few thoughts. It can be found on YouTube.
What’s In The kit?
All the electronics components needed to complete a pair of amplifier PCBs, including 8 matched JFETs.
What Is Needed To Complete The Full Project?
At this time, a complete kit including everything required to complete an amplifier is not available. You’ll need a power supply, chassis, wiring, and a few other parts. Everything you need can be purchased directly from the diyAudio store and well-known retailers world-wide. Suggestions are included in the build guide, and/or you can customize to your heart’s content.
What Skill Level Is Required?
This project is intended for intermediate to advanced DIYers. It may be the perfect project after an Amp Camp Amp. Newer builders willing to do a little studying should have no trouble following the build guide. However, it is critical that builders know how to identify parts from schematics, match those parts to PCB locations based on the silkscreen, and have good soldering skills. Most importantly, all builders are responsible for their own safety and must understand essential safety practices and precautions when dealing with mains powered electronics.
Feel free to review the Aleph Jzm Build Guide in advance if you're trying to determine if this project might be for you. The guide will continue to be updated. The Aleph Jzm Kit Build Support thread is also available if you have questions.
Is it made of Wood?
I mean - Build Guide is certainly written by Witch, it's that good!
@ItsAllInMyHead
You're a gift. Thanks for the update! I know I've already built the original Aleph J Zen Mod edition but I am still excited for folks to try it, it's definitely different than the standard Aleph J. And this most recent version is probably even better with parallel sets of Jfets! Perhaps I'll build it too.
Best,
Anand.
P.S. INCREDIBLE build guide. WOW!
Best,
Anand.
The generosity of this forum contributors amaze me.
Will on be on the "to be build list". Thanks all!
That is an excellent build guide!
Dang, I already have two versions of the Aleph J. Still, I am tempted to build a pair of these boards and swap them in place of the Aleph J SS. Taste test between the standard front end and wakoo ZM front end.
Using output FETs as singles rather than matched pairs has some advantages. There are some very capable devices with higher transconductance and power dissipation that would fit very well into this design.
Great timing Pat. After all the fun discussions happening here. The build guide looks superb. The soon ish is getting real close!
ItsAllInMyHead:
Your absence has been noticed and now answered!
Please! And let us know...Dang, I already have two versions of the Aleph J. Still, I am tempted to build a pair of these boards and swap them in place of the Aleph J SS. Taste test between the standard front end and wakoo ZM front end.
ZM was gracious enough to post a video introducing himself to those that don't already know him and share some thoughts.
I'll add it to the first post ... and you can also click here.
Prior to this video my mind assumed ZM was somewhere near the character "Philo" in 1989's hit movie UHF.
you're welcome; please, please I'm going to blush.The generosity of this forum contributors amaze me.
I seriously thought it was a joke. A clip from the three amigos or something. Nice to see ZM addressing the community, broadcasted from behind the Iron curtain. Aleph is evergreen!I'll add it to the first post ... and you can also click here.
@Jacruzer787 (and others) - Best place to find all the latest documents will always be in the build guide.
They will always be up to date.
@Jacruzer787
Scroll all the way to the bottom of Patrick's link above for all info and see in 'Attached Documents.'
Best,
Anand.
Best,
Anand.
- Aleph Jzm
