Aleph J illustrated build guide
Thanks for the advice guys, I'll go with 30 Ohms with my 19v psu as this should give me approx 500ma which is roughly the same bias as final use in a Aleph J..?
No, in final use it will be running more current. However, if you match them with more current then the voltage will be changing faster as they heat up faster, so it's harder to get a good average reading. With 170mA to 500mA it will rise slowly enough that you can wait a few seconds and then write down what your multimeter shows.
Devices matched at 170mA or 500mA tend to be fairly well matched at higher values as well, so it's a good compromise.
Well, this is how I understand it, anyway. If I'm wrong someone will be along shortly to set me straight. :)
I've tested it at various circuits around the house, and it's pretty consistent at 20mV. I've been unplugging/turning off everything around the house, but nothing is really having an impact on that number.
If you have the option and it’s your house and not a apartment building. You can go to the circuit breaker on the main panel turn off all the breakers except the one that goes to the one circuit that you will be using.
This will make sure things like transformers from doorbell ringer‘s or circuit boards and transformers that are always powered up inside air-conditioning units or heater furnaces they never turn off.
And the next to last extreme measure remove the fluorescent light or LED light in the room and replace it with an incandescent lightbulb.
After all that then you’re 100% sure it’s in your transformer or coming down the powerlines from a neighbors house somewhere in the neighborhood.
Joined 2019
Great suggestion! I just finished up – shut off every single breaker except my audio circuit. Killed anything on the circuit that wasn't part of my system, and then turned everything off individually. All said and done and... still seeing 20-25mV of DC on my lines. :(
Is it advisable to put the snubber network Eric described before the transformer in this instance? Right now I have a 3300pf line cap at the AC input bridge.
Please note: this is my first rodeo :D
Snubber goes where the secondary windings connect to bridge rectifiers.
DO NOT place the snubber at the primary side.
3.3nF / 250V AC cap is okay in parallel to the primary.
...hmmmm... I would place the transformer next to the IEC (110V AC mains IN) connector, crimp (use the crimping lugs) the thermistors straight to the bare copper wires (no need for a terminal block), and drastically shorten the mains wiring. All of this can be floating on top of a transformer, or use 3 raiser pannels.
Joined 2019
Sounds good on snubber. Here are a couple of detail pics of where I’m at now. Let me know if you see areas for improvement (aside from the shortening of mains wire and including a snubber)
The mains wiring runs in parallel with one of the secondary wiring. There's the reason why the manufacturer chose to separate primary and secondary wirings' tails as much as possible:).
Anyway, I would look at shortening the mains wiring.... or at least, getting rid of a terminal block, and then running the full mains loom length between the "floating chassis" and the case bottom plate.
But, you should definitely consider my suggestion to shorten the mains wiring, as I already mentioned in my previous post.
Joined 2019
Buzz update
I opened the amp up and repositioned, twisted, loosened, etc the toroid, all with no change to the buzz sound. Also repositioned some of the connections based on feedback. I heard back from John at Antek, and he thought 20mV DC on the line was negligible and wouldn’t cause the buzz. He’s sending out a new transformer on Monday, so we’ll see if it’s the transformer or something else. Will report back.
Joined 2016
Good to hear that Antek has great customer support! Hopefully the new toroid solves the issue, keep us up to date.
Joined 2003
I used Antek, 500VA "unshielded" version and it is quiet as a mouse...dead silent in fact with very efficient speakers. Nothing noteworthy in terms of wiring, fairly straight forward....will post internal pic when my cat gets off of it!
