Here is the question: mouser did not send me 22K for IN - input. Can I run amp without it if I do not use balanced input and connect In- to the gnd?
Dodo
put temporary 2 x 10K in series instead
cuttin' resistor from Pa's schematic is usually tough challenge
Thanks ZM! I am not that bad ;-) one local guy asked me to come and help him to fire up his amp. There are no other resistors at his place. That's the thing. I will go and check local radio store tomorrow.
If it was my amp I would try to improvise and probably fire it up without the resistor, but the amp is not mine 🙂
Setting bias, choosing inputs ?
Hi.
Speaking af inputs, i was wondering the following ::
1. Do i have to short both +IN ans -IN to GND when setting ?, or does it matter at all ?
2. What is the difference of using -IN or +IN and GND for normal RCA inputs ? (I see a C1 cap at -IN, whats the use of that)
// Jesper
Hi.
// Jesper
everything just cobbled together , when setting bias
meaning - + input , -input and ground
just tie them together ..... in one big knot
Okay....
I thought so.. Making sense to me 🙂
I am not there yet ... Have to solder a bit more.
// Jesper
// Jesper
Wonderful! Congratulations!'
Let it sit for 1/2 hour and see if anything needs adjustment.
Those are beautiful heatsinks - they should run fairly cool (for an Aleph...)
Aleph J fro, scratch part II - Stuffing and testing
Hi..
Please look at direct link to photobucket, as the pictures are getting weird, when linked direct here.
I must say, that i am a little impressed by this amp. I tried to give it 1v/pp ~1000Hz sine, at the input. Looking at the output, it (gains) 8 times the input.
I tried to crank up the inputvoltage, giving it more volts, ended up with the Aleph J clipping at approx. 30-35v/pp
This is excatly what the manual says... 😎
Next part is to listen to it.
// Jesper
Aleph J From Scratch Slideshow by Jesperlykke | Photobucket
Hi..
// Jesper
8 times ?
time for ophthalmologist ....... .or brain doctor .......... or Magura
you choose ....... 😉
As a matter of fact.
I was seeing approx. 8v/pp sine (not accurate) at the scope, when feeding it with 1v/pp...
The sine was fine, so to me, everything looks normal.
//Jesper
//Jesper
Jim, for the Aleph Will it be an issue using 74GR instead of BL fets, Supplier has lots of GR and can match at .1.
The Greens are low on the Idss scale, so not ideal. With a few mods to the circuit they could be made to work, but if they have the Blue, then use those.
Edit - I just saw Zen Mod's post - paralleling greens is a perfectly good idea. You just need more of them. 🙂
GR - green
BL - blue
V - violet
That is Toshiba's code for Idss range
GR - green
BL - blue
V - violet
Zen, to make sure I understand, 2 plus 2 would simply be putting two GRs in parallel, gate to gate, drain to drain, and source to source, and then installing them together in the pcb board instead of one 74BL? Is this correct.
Thanks, John
Thanks, John
either like that , or piggy-back ( underneath the pcb )
as one of our Dodo's is sayin' - If it's not Boeing , I'm not goeing .....
in other words - better more xconductance than eeny weeny ...
- Aleph J illustrated build guide
