ALPHA 20w PCB production is complete, shipping prep is underway. We should have boards soon!
Awesome!
Thanks to you Hugh, for a great amp design and thanks to JPS64 for a super layout. I am looking forward to building the amp, but not to leaving my vacation here in TCI.
Fantastic news X!!
Looking forward to getting those boards in hand🙂
Doesn’t time seem to speed up when your on vacation? Enjoy the rest of your week.
Pcgab,
Sweet setup around the fireplace!
My fans arrived and seem to fit the Dell coolers perfectly. They are the 80mm size. Currently, I set them up under my MoFo and they are VERY quiet. LEGO’s always come in handy🙂
Pcgab,
Looks good Vunce. What are you using to fasten the fans to the coolers? Can you get us a link for the fans? I have another day here...
Thanks,
X
Thanks,
X
I haven't settled on a way to fasten them to the coolers yet, I've got a couple ideas though. They come with silicone "feet" on the corners so you can stand them up or lay them flat on top of a component. Here is the link:
https://www.acinfinity.com/
Pcgab,
Thanks!
I love the lego fan stand, that's awesome!
I wonder if making a mounting bracket for the fans to mount on iso mounts (silicone spongy grommets or something) to the chassis baseplate might be better? You could mount them securely enough and with proper damping to help any vibration related issues, and not have to try and mount to the rather thin and delicate fins of the heatsinks.
Good news for all those who are waiting. 🙂
Just got my order from Digikey, I'm amped to get the boards and get to building.
I'll flog myself for the bad pun, rest assured.
PCB shipment has arrived at DHL hub in Cincinnati OH - delivery by evening tomorrow.
Wow, that's fast production!
Awesome news X!
The BOM I attached in post 199:
http://www.diyaudio.com/forums/soli...rid-aleph-alpha-amplifier-20.html#post5329240
X can answer better than I certainly. The above is the BOM I used to order. I haven't assembled a prototype and will likely wait for the boards to arrive as they're already shipped to X.
X, hugh, et all:
For C101, would a 330pF 100v FKP2 be ok?
Schematic calls for 220pF. I have 330pF on hand if it will work.
~Gable
~Gable
That should be fine. It’s an RF interference filter so you can calculate cutoff frequency with 2k2 in series. 330pF gives 220kHz - should be fine to let high slew rate audio through and keep out RF.
pcgab, your BOM was helpful. Is the 2/2 version still current?
BK
I may have missed this in the bom:
C115 1uf 63v MKS4
Looks like the same cap as C121
C115 1uf 63v MKS4
Yes, both of those are 1uF MKS bypass caps for the big electrolytics.
The PCBs that JPS64 designed look great. Perhaps one of the prettiest PCBs I have seen. The double thick copper with ENIG finish and blue solder mask work real well together on 2mm thick board. But the star of the show is the crazy intense number of vias that connect parallel thick traces on both sides of the board for the high current flows and the ground plane.
Here are some photos of the boards and a closeup of the backside. I am afraid to ask how many vias that is and how many drill bits may have been used to make all of them?
Top and bottom side:
Closeup of back side:
JPS64 put some reallly nice touches on it: one of my favorites is the choice of spade connectors or flying leads (for the Pass forum diehards) for the power supply and speaker output connections. UMS compliant MOSFET and standoff positions is also another great feature. Options for NP0 SMT caps or silver mica on C105 and C113 are also great choices to have. Nice job JPS64!
- Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
