My parcel was at Post for 3 weeks and was returned to Vitaliy by the Customs - don't know the reason.
He said he was shipping again by EMS on 22nd, and he did. The tracking number he provided is showing that the parcel was cleared by the export Customs and is in transport.
So it is fair to say that Vitaliy is holding on to his words, but also he is affected by external factors beyond his control and will.
Personally I have no reason not to trust Vitaliy - still, I think people might feel better if a tiny bit more of information that explain delays would be forthcoming.....
Perfectly summarized ... transparency avoids doubts .....
I hope to all of you to receive your cards ...
Thanks to Vitaly who seems to drool over it ....
![faint :faint: :faint:](https://files.diyaudio.com/forums/images/smilies/faint.gif)
I am testing the Aufiophonics Opa627, compared to the 1656 they have a fuller sound, a nice mid-bass and less very high tones.
The 1656 op-amps sound brighter but still pleasant, it's just a choice of tastes.
I haven't tried the LM4562 op-amps yet, maybe I'll try them tomorrow, hope they go well.
Do the op-amps need a running in?
Good Morning,
sounds good....
![headphones :hphones: :hphones:](https://files.diyaudio.com/forums/images/smilies/hphones.gif)
It is good that you can test different OPAs with Akita.
![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
I'm curious what "LM4562" sounds like ...
We should also test the OPA1612 ...
Good day guys!
All in progress.
I ordered ADA4610-2
A friend of mine says that they give a surgically accurate sound. My friend is a sound engineer.
Good morning Vitaly.
that sounds good ...
I testing in my amp:
OPA1656, OPA1602, OPA1612, OPA1632, OPA627, THS4131, AD711, NE5532, MC33272.
All opamps have good sound.
My likes- OPA1632, THS4131 - this is full differential opamps,
Next - OPA627 - very good sound for me.
MC33272, good old opamp, very warm, as tube sound.
I writeWait to talk about anything else than to finish this.
This project will be in any case.My next project as soon as we finish the current one.
Good Morning,
sounds good....
Yes of course, unfortunately yesterday I took a day to solder the new Alps potentiometer, the board to solder the potentiometer directly did not work on a loudspeaker channel so I had to try many attempts before the Akita started working again.
Even op-amps if not positioned correctly or inserted without pressure may not work.
Thanks to the support of Vitaly which is always available in private messages I was able to restore everything.
Good day guys!
All in progress.
I ordered ADA4610-2
Hi, what do you mean when you write your amp, is it another project?
On our Akita if we want to replace the op amps, how should they be listed in order not to make a mistake in the purchase?
ADA4610-2, must it always be soldered on Dip8?
For any amplifier, for Akita you need an adapter.
I ordering opams in MSOP8, need adapter MSOP8>DIP8
so it also works 1632 on Dip8, right?
Can it be updated Akita to the next version in the future?
It would be nice
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
