Cardone, what is the output Z of your tube preamp and what is the input Z of the TPA3255? What is the Maximum output of your tube preamp? What are your sources. You have to know those before you can make a decision.
Normaly rule of thumb, input Z should be 10x output Z. If your tube preamp has an output Z of 1K then a 10K pot would be good choice.
Example, My DAC puts out 2 Volts, my tuner 250millivolts, my minidsp, if used, puts out 900millivolts. My preamp uses a Lme49600 as an output buffer, it can easily drive a 1k volume control or speakers directly (250 ma max) my preamp has a gain of 12db so it can drive almost any amplifier from any source to full output if required.
Hello everyone,
I got my amplifier from Vitaly. It was very interesting to compare it with what I had in stock - Icepower 1200as2 and 50ASX2 in bridging and some tweaks.
The main difference between Vitaly's amp is how much freer it is and less schematically it delivers music. For me personally, it is essential to make a choice in this context of comparison.
Thank you Vitaly and good luck in your new projects!
There are DACs now have 32-bit volume control, wouldn’t that be more than sufficient to perform past the limits of audibility?OK, but digital adjustment degrades sound quality at low volume levels
Is the volume control on DACs usable? | Audio Science Review (ASR) Forum
Hi multisync, I listen to Tidal HiFi via Chromecast Audio optically connected to the Topping E30, sometimes via the UAPP application in usb.
What potentiometer should I take, 10,20,30,40 or 50K?
What if you listen at a low volume?
Hello everyone,
Hello everyone,
Hi, after how many hours did you start hearing the Vitaky amplifier well,
is it version 3?
The amplifier stayed with me for only 24 hours. Initially it was planned for a small project, which I did not do for myself.
I am sure that after a sufficient hour of burning, its sound signature will only improve itself. But even this short time was enough to form a positive impression in comparison.
Does it perform good with your speaker (W5) ?
@vitaly, when is the next lot getting shipped? I am eagerly waiting for my amp board to be shipped 🙂
the amplifier was originally intended specifically for this speaker. Its power is convincing.
Hello Multisync,
I use (currently) as an amplifier ICEpower 125ASX2 (without potentiometer) in stereo with 2 Teufel 2x200Watt 4ohm) tweeter, midrange and 2 bass tone ...
The preamplifier is an FX-AUDIO TUBE-03 Valves 6K4 Stereo Preamplifier.
FX-AUDIO TUBE-03 Valves 6K4 Stereo Preamplifier Black - Audiophonics
I exchanged the following parts:
1. Original Chinese 6J1 against GE JAN 5654W
2. Original fake NE5532 against LME49720NA
As soon as Vitaly amplifier is there I will test it.
I think it's great how many people deal with it ...
You never stop learning ...🙂🙂 ...
Many greetings and Happy Easter
Cardone
Ok, I hope this is not your preamp or there is a mistake in the frequency response. According to this web site the bass is down -10db at 20hz and -3db at 50hz
you should measure yours to be sure.
The output Z might be 600 Ohms. You can use a 10K ohm volume pot between your preamp and the poweramp. There are many affordable stepped volume pots on Ebay. I have bought several for around $20. I have one that has failed after using it every day for 5 years. The contacts on the wiper failed on one channel and it was not repairable.
One of the best benefits of stepped volume pots is the nearly perfect channel balance.
Hello everybody, I know we waited a long time for the amps and mine was supposed to go out this week. I guess that it will be sent within days. However, I had to buy an extra amp this week due to an issue and hence I am happy to "sell" my amp to someone on the waiting list. I have on order a fully assembled amp. If Vitaly is OK, the buyer can pay me the same amount I paid him and get sent the amp.
Vitaliy is OK so feel free to PM me if you want the amp and we can take it from there.
Hello Multisync,
Cardone
Hi Cardone! I tried this little tube preamp ...
I deleted it .... I thought it would sublimate the sound ...
It adds distortion!
Well I put it back in its box!
Too much loss of detail. Really the tubes have killed the performance of my dac.
With an AKM dac, the sound is just perfect! (I tried dac saber ... the sound tired me in the high of the spectrum) Have a nice day !!! 😉
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
