Hi all, I have my amplifier assembled but am having problems with ground loops/buzz. I've started another thread if anyone would like to help. Thanks
Hi, I'm sorry I can't help you, try writing to Vitaly privately so he can help you
Hi everyone, my Akita has been in use for more than 40 hours, what do you say is enough to judge how it sounds?
Unfortunately, due to the covid-19 block, my family members are all at home, I can rarely listen at high volume
Think about First Watt
Sorry, I don't like listening at high volume with efficient speakers, they only bring headaches.
Salvation! Nerone, The volume at home is managed by the dac ... So potentiometer fully!!!
Dac ak4497.
Thanks, tomorrow I'll try with the pre E30.
I can't wait for your amp to arrive to see how you connect it to the vu meters
OK, but digital adjustment degrades sound quality at low volume levels
So what's the best solution?
A tube preamp?
Good pot)))
to - 30db in digital, -30 to silence potentiometer
I can't understand, do you mean that a good potentiometer similar to the one already mounted is better or should I install another one?
Would you have to use linear or logarithmic potentiometers in this case? And if a 10 to 50K ohm?
For example, in my ICEpower 125 I have not installed a potentiometer and the volume is regulated by a tube preamplifier.
I am satisfied and have not made any changes to date ....
- Group Buys
- Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
