• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
AK4490 USB Dac with dsd support.
So, i've read the 85 pages during the past day....it was a lot of reading but now i'm confused. Just because i'm a newbie in the diy audio. My question is, if i buy the dac with the discrete, can i connect directly to any amp? what are my limitations? for now i can only buy the dac with discrete, and later the preamp. And if i want to connect my cd player to the dac? isn't a optical connection needed? I assume the new dac will have this...or i am just confused. Thank you, and sorry for my english.
Fantastic Work Sonnya. Congrats
Hi to everyone, i'm finally listening to the dac, what a beautiful sound, greatly better than my old cd transport+dac ( Nortstar 192 ).
The only problem is that the output are inverted, the lef channel connector is in reality the right channel, is it normal or just mine???
A question, is it possible to drive an headphone directly from from the dac output or do i need an amplifier?
They are in test phase Right now
Sent from my iPhone using Tapatalk
Hi, i repeat my answers:
- the output are inverted, the lef channel connector is in reality the right channel, is it normal or just mine?
- is it possible to drive an headphone directly from the dac output or do i need an amplifier?
Hi factory2nd,
It is only inverted on the opamp output module I believe and this can be corrected in software. Just swap the cables inside the chassis, no one but you will notice.. 😀
Did you update to the latest firmware? Maybe it is already fixed in there.
Ciao!
Do
I Know i am a newbbie but can anyone explain! Thank you!
